driveline angles question - Defender Source
Old October 21st, 2015, 06:35 PM
Attached is a picture representing the angles on my truck.
The front works well. I'm happy with it.
After some recent work however, the rear has developed a low speed vibe. It's worst at slow speeds, improving steadily up to 35mph, after which it is pretty much undetectable.
1. My engine driveline is not level to the ground. It's angled down towards the rear diff at exactly 2 degrees.
2. My rear pinion is angled up at exactly 4 degrees.
3. The rear driveshaft (stock) is at angle of exactly 20 degrees positive from horizontal (as measured from the rear pinion)
Does anyone have any precise technical recommendations on what to do about these three measurements?
Is the engine driveline supposed to be perfectly horizontal?
Old October 21st, 2015, 06:38 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Are your trans mounts shot?
1970 SIIA 88, Sold
Old October 21st, 2015, 06:43 PM
I don't believe they are. There are two. Both are composed of two rubber pucks sandwiched together, along with a threaded rod connecting the transfer case to the frame.
Both appear fine and of standard dimensions. Not much to go wrong with them, I presume.
BTW the picture of the engine is a Duraqtorq w/ MT82, but I'm running a 200tdi with an LT77.
Old October 21st, 2015, 06:48 PM
What was the "recent work"?
Old October 21st, 2015, 06:58 PM
Terrafirma inverted relocation cones installed.
Old October 21st, 2015, 07:00 PM
ATX_D110's Avatar
ATX_D110
Victor
1985 RHD D110 (SOLD)
FWIW - When I installed a +2" on my 90 I immediately had a noticeable increase in front vibration not only under the front but has the whole dash vibrating more than "normal" - All at or below 20MPH. Also noticed my RPM's where running higher. Changed back to stock height and extra vibration gone and RPM back to ideal.
Old October 21st, 2015, 07:03 PM
grnrvrs's Avatar
grnrvrs
Paul
88
On my series rig, the rubber on my trans mounts deteriorated to the point of collapse, which changes the prop shaft angles and introduced vibes. It was easy to see/fix.
Assuming the chassis side of your engine mounts are stock, as opposed to 'custom' welded mounts, collapsed trans mounts could explain why it tips rearward.
x2 on the recent work q.
1970 SIIA 88, Sold
Old October 21st, 2015, 07:38 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You could add some washers to the trailing arms to rotate the rear pinion down to be level with the TC.
Old October 21st, 2015, 07:50 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
^ this
But check your mounts first. Get in the with a crowbar and see if you can see them move. I had one separate a while back and it looked fine from the outside but was very much not OK.
Do the U-joints have any play?
Old October 21st, 2015, 08:56 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
I have found this info drive lines from Tom a Woods to be suited to this.http://www.4xshaft.com/
------ Follow up post added October 21st, 2015 06:00 PM ------
I just read my post. Boy did I mix up words and add some. Sorry. Wine just kicked in. Still good info to follow on geometry.
Old October 21st, 2015, 10:21 PM
I will check all of the above, thanks.
One important question: if the transfer case mounts are brand new, should the engine drive line angle be perfectly horizontal??
Old October 21st, 2015, 10:27 PM
cascade90's Avatar
cascade90
Mason Worley
No. Typical is 2-4 deg.
Old October 22nd, 2015, 07:34 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
X2 on the tcase mounts. I had one fail about a year ago. My vibes are back so time to recheck.
Old October 22nd, 2015, 07:41 AM
If the drive line angle is below the horizontal by 2 degrees, what should the pinion angle be? Some reading shows me that the pinion should then be 0-2 degrees up from the horizontal. But I have no idea if that is really true.
Old October 22nd, 2015, 09:28 AM
The two flanges should be parallel, but a few degrees is not going to be causing you vibes. You need to look elsewhere for the problem.
Old October 22nd, 2015, 09:29 AM
ezzzzzzz
Mark Garrenton
There are two trains of thought. First, equal and opposing angles with a stock driveshaft. The reason is the u-joint actually speeds up and slows down when the rotating angle is anything but 0. By making angles at the TC and pinion this rotational speed is equalized reducing wear and vibration. The other approach is using a double cardon joint at the TC and pointing the pinion to create a 0 degree angle to the driveshaft. This works where the rear axle cannot rotate in acceleration/deceleration. If you were using leaf springs that pinion angle is usually slightly upwards a degree or two the account for that rotational force. This a very simplified explanation but it will work for you.
Side note, most drivelines have some angle difference to promote u-joint lubrication. In the general operation there should be enough suspension deflection to cause angle variation to also promote this lubrication.
Old October 22nd, 2015, 09:50 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Rent my
Old October 22nd, 2015, 09:56 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You shouldn't need a rear DC driveshaft if you're running 3" of lift or less. The stock two ujoint driveshaft should be sufficient provided the pinion and transfercase angles are matching.
Old October 22nd, 2015, 10:34 AM
1of40's Avatar
1of40
1of40
Tcase slop I believe can be a culprit as well.
Old October 22nd, 2015, 11:29 AM
doktorno
Chris deZ.
1995 Defender SW
Sonoronos, what is the condition of your rear a-frame ball joint and bushings?
Need an older Defender 90 looked at in Los Angles (Pasadena/Alhambra) defendernut For Sale - Vehicles 8 March 23rd, 2015 11:16 PM
Rover Mechanic in Los Angles? Flagg Defender Technical Discussions 15 January 18th, 2013 01:43 PM
Quick driveline question D90user Defender Technical Discussions 2 May 11th, 2006 09:29 AM
3 Link Angles To Reduce Vibs ? jorge Defender Technical Discussions 1 December 31st, 2005 02:36 PM
Drive Shaft Angles TDI Guy Defender Technical Discussions 27 March 17th, 2004 06:10 PM
