driveline angles question - Page 4 - Defender Source
Old November 16th, 2015, 12:23 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Originally Posted by evilfij View Post
He just needs to accept that he is not designing parts for a space ship he is designing them for a 30 year old british tractor.
true but you have to admit my idea would be more fun
Jimmy Buffett
Old November 17th, 2015, 02:26 AM
You guys crack me up and I really appreciate your humor.
I think I've just been spending far too much time working on this truck lately and I just need to drive it and have fun at NOVA HH.
Old November 17th, 2015, 08:21 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Between this and replacing the floor you should have just started with a Disco frame and made a D100
Love the fab work!
Old November 17th, 2015, 08:31 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Ed, will this off-center the rear wheels enough to cause rubbing concerns?
Old November 17th, 2015, 09:24 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
ed I assume your 90 is not an NAS.... if it is you may have a conflict with your rear gas tank
good luck with your search
Old November 17th, 2015, 01:34 PM
Or wheeling with us like this
Originally Posted by pendy
I'm here for the D's
Old November 18th, 2015, 09:57 AM
Hahah! I think that was the day that Jeff stood on my cage and tried to shake my truck off the rock!
Yeah, i'll be back as soon as this truck is back on the road...
Clay - I think my wheelbase is slightly (like an inch) longer than usual due to the front radius arms and rear arm bushings, but it doesn't seem to present an issue with my small tires.
Ron - Good point about the NAS tank, the good thing is that I have a UK truck with a side-saddle tank and therefore there's very little back there, as the picture below shows
So, it's all installed along with new a-frame bracket bushings.
Old November 18th, 2015, 10:05 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Nice work! But stick some Grade 8 bolts in there. (Sorry - I recall commenting on your bumper bolts).
Old November 18th, 2015, 10:15 AM
Hah! Where do I not have Grade 8's? (Actually, I have grade 5's and 300-series stainless in certain places that don't need them, because, as engineers know, grade 8's are only required where they are required...)
Old November 18th, 2015, 10:19 AM
down_shift's Avatar
down_shift
Russell
The long bolts passing through your thingamajig. They look to be 3 or 5. Just used to seeing larger and thicker washers and nuts and zinc coating based on our local suppliers. Perhaps I frequent Tractor Supply too much.
Old November 18th, 2015, 10:24 AM
Except the grade 8's plating is a lot better.
Old November 18th, 2015, 10:26 AM
down_shift's Avatar
down_shift
Russell
LOL. You spend a 100 hours designing and $$$ on this milling this cool block of of metal yet pinch a few bucks on the readily available easy stuff. Candidate for the cheapfu$& thread?
Joking aside, great work. Hope you created a market for this and sell a few hundred.
Old November 18th, 2015, 10:32 AM
I see. There are 4 bolts in the thinamajig, two in the top, and two in the bottom.
The 2 tops are 1/2-20 Grade 8.
The 2 bottoms are a little special - high visibility blue M12x1.75 Class 10.9, the nuts are Class 12 (uncoated)
I think what you think are grade 3/5 is due to the silver color. In actuality, the nuts are black, the bolts are blue, and the silver is a very liberal coating of zinc antiseize.
I am a cheapfu$&, but I have to be. You could say I'm a professional cheapfu$&. One day, my truck is going to end up on the "Rovers That Suck" thread, but I could care less. I rest easy knowing that everyone else's trucks on here are just as bad as mine or worse. No matter what people "say" on defendersource, I know what they actually do in private.
Old November 18th, 2015, 10:49 AM
Here's a better picture.
I should sell a grade-8 cad-plate rattle-can so that people can post pictures of their build on the internet and get accolades for using grade 8 everywhere.
Old November 18th, 2015, 11:01 AM
Stock bump stops? Is there adequate shock travel and a-frame clearance?
Old November 18th, 2015, 11:05 AM
Yes. The A-frame clearance is shocking, several inches even on the stops and the huge chunk of steel there. There's a lot of room up there without a fuel tank.
With the Rockware hoops plus RS5012s, no problems.
And that is assuming that the TF027V springs would even allow the bump stops to touch.
I need to make a vehicle dynamics program on the web that allows people to modify and extend rover suspension components so they can see what's going on underneath the truck.
Old November 18th, 2015, 11:48 AM
Wouldn't spacer blocks on the frame side of the A-arm do the same thing, with less complication?
Good point, and I did think about that. I think the nail in the coffin for me was that the frame-side spacers would have to be approximately 3" thick to correct the angle the required amount. Not impossible, but the logistics were intimidating.
One thing to note is that I actually don't really understand the design of the a-frame brackets and how they respond to articulation. If they were designed to articulate freely, the pivots would be angled parallel to the frame. In the rover, they are angled inwards towards the rear. This forces the bushings to bind as the suspension is compressed and extended.
So these spacers (regardless of which end of the a-frame they are located) change the resting angle of the a-frame, and therefore change the amount of binding that occurs on compression and extension. I didn't account for this because i don't understand the mechanics.
-Jeff
I think you would interfere with the exhaust. Possibly the driveshaft as well.
Old October 29th, 2016, 03:56 PM
So after some measurement, it appears to me that the following are true (approximately) - when using an A-arm spacer and RTE arms.
Stock Ride Height:
horizontal pinion: 11.14 degree driveshaft angle (from horizontal) - delta (degrees from stock): 0 degrees
pinion pointing at lt230 output: 7.6 degrees driveshaft angle (from horizontal) - delta (degrees from stock): 0 degrees
4" drop/lift:
horizontal pinion: 21 degree driveshaft angle (from horizontal) - delta (degrees from stock): 9.86 degrees
pinion pointing at lt230 output: 14 degrees driveshaft angle (from horizontal) - delta (degrees from stock): 6.4 degrees
12" drop/lift:
horizontal pinion: 40.78 degree driveshaft angle (from horizontal) - delta (degrees from stock): 29.64 degrees
pinion pointing at lt230 output: 28.45 degrees driveshaft angle (from horizontal) - delta (degrees from stock): 20.85 degrees
independently: Pinion angle change vs. articulation:
Stock ride height: 0 degrees.
4" drop/lift: rise 5.9347 degrees (from stock)
12" drop/lift: rise 18.1945 degrees (from stock)
This is assuming 23.5" upper arm distance from pivot to ball joint and 28.5" lower arms.
Stock upper arm distance from pivot to ball joint is 22" (removed A-frame spacer). Not sure how long the stock lower arms are, but I'm assuming probably around 28.5"
Not sure how much it affects the overall change in angles during articulation, but I can't imagine much.
The reason the pinion angle changes the overall change in driveshaft angle is because the pinion to axle centerline distance is approximately 11.5".
Old October 29th, 2016, 04:02 PM
1of40's Avatar
1of40
1of40
Are you going to bring this thang to RoTR and challenge it in a couple weeks?
Need an older Defender 90 looked at in Los Angles (Pasadena/Alhambra) defendernut For Sale - Vehicles 8 March 23rd, 2015 11:16 PM
Rover Mechanic in Los Angles? Flagg Defender Technical Discussions 15 January 18th, 2013 01:43 PM
Quick driveline question D90user Defender Technical Discussions 2 May 11th, 2006 09:29 AM
3 Link Angles To Reduce Vibs ? jorge Defender Technical Discussions 1 December 31st, 2005 02:36 PM
Drive Shaft Angles TDI Guy Defender Technical Discussions 27 March 17th, 2004 06:10 PM
