Drive shafts appear to be wrong after conversion - Defender Source
Old August 6th, 2013, 12:23 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
I have converted from a 200tdi with an lt77 to a 300tdi with an R380 and trying to get everything back together here it appears the drive shafts are no longer correct because of the new location of the output for the transfer case. Does anyone have any info on if this was supposed to happen and the solution? Thanks any help is appreciated. I didnt find anything in the search
Old August 6th, 2013, 12:29 PM
Sounds like a trip to the driveshaft shop is in order. I had both shafts properly sized and all new joints for about 350
Old August 6th, 2013, 12:31 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
that is what I figured do you know the correct lengths?
------ Follow up post added August 6th, 2013 10:32 AM ------
it is a D90
Old August 6th, 2013, 12:46 PM
NAS D90 shafts are the same length as stock 300tdi D90 shafts. I am sure someone has a set of stockers laying around you can buy on the cheap.
Old August 6th, 2013, 12:51 PM
anfonee1's Avatar
anfonee1
Jeffrey
1984 D90 RHD SW
If anyone has available let me know. Thank you.
Old August 6th, 2013, 02:22 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I have a similar situation. My truck has been converted to 300tdi (defender spec) with a r380 from who knows what engine and transmission (unknown). Both drive shafts need replacing.
Would probably prefer stock over aftermarket (cost reasons), but I've had problems getting correct fitting parts in the past . Punching in a VIN number from my truck to determine correct drive shafts will probably yield incorrect part numbers due to the swap.
Can anyone confirm the size of the NAS spec front and rear drive shafts (if in fact NAS driveshafts will work with 300tdi trucks) before I go ordering them from a vendor?
Measurements taken from my truck:
Front drive shaft (flange to flange): 24 7/8"
Rear drive shaft (flange to flange): 28 1/8"
Any help would be appreciated.
Old August 7th, 2013, 11:27 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I know that 300tdi defender shafts are the same length as V8 5 speed with the LT85 santana box.
Old August 8th, 2013, 08:14 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Are your engine mounts in the manufacture's original location? What rear axle do you have? (if you are looking at the rear shaft too) The 300 with the R380 is the same front shaft as any D1 or NAS 90.
conversion
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
What kind of DC shafts and axles is GBR selling? cbass Defender Technical Discussions 12 July 19th, 2005 01:03 PM
New HD Drive shafts TDI Guy For Sale - Parts 0 March 1st, 2004 08:51 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 11:51 PM
