drive shaft play - Defender Source
Old June 29th, 2007, 12:27 AM
bjenk
Brian Jenkinson
1994 D90
drive shaft play
My wife was coming home this evening and said the 90 has a wierd clunch. I drove it and was stumped. It sound like something rubbing at times, then clunking, and then like rusty spring being stretched. there is no rhythm of sequence. I made the car jerk a couple time and it is worse. While the sound it going it goes away if I coast it. It sounds as if it is coming from the rear of the vehicle even when my wife drives slowly by me.
I checked the u joints (I noticed that the rear diff u joint is cracked at the bearing on one). I greased the u joint and shaft. Noise still there. Shaft is tight with no play what so ever.
Front drive shaft has about 1 inch of play in it. I will check the fluid and then disconnect my drive shafts and see if I can narrow it down.
Can I drive with either drive shaft removed for an extended (one week) period of time?
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
D11 front drive shaft jorge Defender Technical Discussions 3 April 12th, 2005 08:03 AM
Drive Shaft Angles TDI Guy Defender Technical Discussions 27 March 17th, 2004 06:10 PM
front drive shaft jorge Defender Technical Discussions 6 December 9th, 2003 11:23 AM
