Drive shaft bolts size - Defender Source
Old April 15th, 2011, 12:04 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I was told that the rear drive shaft bolts at the drum brake are 3/8 (24 thread) x 1.5 inch.
I just wanted to double check my memory, as I didn't write it down.
I searched and didn't find anything.
Old April 19th, 2011, 09:31 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
According to Microcat 1 3/4".
I was looking at one today and that sounds about right.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 20th, 2011, 07:32 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Half the sites I found say 1.5, the other half say 1.75.
I guess I'll get both, grade 8 will cut it I hope?
Old April 20th, 2011, 08:03 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I'm pretty sure stock is grade 5, but certainly grade 8 is fine. Just be sure to not mix bolt and nut grades.
The only reason I switched mine to grade 8 is that I can get very corrosion resistant bolts in fine thread, locally.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 20th, 2011, 08:18 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
great, thanks
Old April 20th, 2011, 12:33 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Well, I measured one this morning and they are 1 1/2" and they are the originals, so I guess either will work.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
bolts
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
Rear Drive shaft bolt size Buckon37s Defender Technical Discussions 14 October 14th, 2006 04:20 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
bolts or at least size.. januconn92 Wanted 0 September 5th, 2005 01:54 PM
