Drive Shaft Angles - Defender Source
Old February 21st, 2004, 06:21 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Drive Shaft Angles
Can anyone check there front and rear pinion angles and drive shaft angles from the flat bottom part of the 3rd members? I am trying to set mine up and since my truck is adjustable both in the front with the 3-link and in the rear with the RYM rear links, I want to have an Idea what to do. I have no clue.
Old February 21st, 2004, 09:52 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I don't know what angles I have but I lifted my D90 2 1/2 to 3"
The Rtym. trailing arms with both of the spacers on each side eliminated my driveshaft vibration.
I don't have any vibration from the front but have a set of their radius arms on the way to get the springs and bushings back to where they need to be.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old February 21st, 2004, 11:08 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Randy, in the tech section there is a small write-up about adjusting the 3 link. They give you a length to start out with, and then you just have to play with the fine tuning.
Old February 22nd, 2004, 01:19 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Where do you measure the angle from in the front?
Legend in My Own Mind.
Old February 22nd, 2004, 08:52 AM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Did you install the rock guard for the 3 link yet? If so, put the angle finder on the bottom of it. Should be adjusted to around 2 degrees.
How in the world have I spent this much money and still don't have a running vehicle?
Old February 22nd, 2004, 09:36 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yes Chris, the rock guard is on. Would the 2 degrees be basically a stock castor setting?
As for the rear, If I set up the pinion for a standard d-shaft, it appears that the d-shaft angle is about 18 degrees at the joints. Isn't that too much angle for a standard joint?
IF I try to set the rear up for a CV style shaft, The links don't have enough adjustment to turn the pinion to point up to the t-case. Ahhh what to do.
Old February 22nd, 2004, 10:51 AM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Yeah, 1-2 degrees would be a stock setting. Randy, keep in mind that those pinion angles are going to change once you get the truck completely together and loaded down. As for the rear, I am goind to have to think about that one.
Old February 22nd, 2004, 11:00 AM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Randy, are you saying that you have -18 degress of castor? This would have the pinion pointing towards the ground, rather than towards the t-case.
Old February 22nd, 2004, 11:24 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
OK. Chris. 2 degrees under the rock gard would be about stock castor.
when I said 18 degrees, I ment the rear d-shaft angle at the u joi nts. That is what it is if set up for a standard d- shaft. Doesn't that seem too steep for standard u joints?
Old February 22nd, 2004, 02:51 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Randy, I checked Tom Wood's site. It says that a standard u-joint will be OK to about 15 degrees, but you will have vibration more than likely. And that 15 degrees is only good if the t-case falnge and the flange on the pinion are parrallel. If they aren't, the 15 degrees figure decreases. I would contact RTYM in the a.m., and get some info. Hell, you paid good $$$ to fix this problem, so they should have the answers of why it is not getting you down below 18 degrees. Hope that helps some.
Old February 23rd, 2004, 12:30 AM
redrover
Guest
Posts: n/a
randy
Randy, it sounds like you understand the basics of driveline theory. If you use a stock drive line in rear, you need the flanges/yoke to be in parallel. This would most likely mean making your trailing arms longer. BUT if you are going to use a double cardan style driveshaft, then you will want to turn diff upwards until it points at the transfer flange. Now I run ome764 coils with a 1.5 spacer. In my case, in order to have the rear driveflange zeroed out with the shaft I shortened my trailing arms so much that my wheel sat way forward inside wheelwell. I didnt like this setup for ideal rock climbing. The wheelbase is already to short to start with. So I had RTE send me a Disco A-arm extension. Now if you just install it as per instructions, it{A-arm } will rub on fuel tank. So I redrilled it. The new lower hole locations worked perfect. It tilted pumkin up about 5ish deg , it recentered my tire in wheel well , and there is no vibration. I sent some info to steve at RTE. There is about 3/8 clearance at tank, and that distance is a mile when cycling suspension. I will take some photos Mon. JP
Old February 23rd, 2004, 12:59 AM
redrover
Guest
Posts: n/a
photos
Here is a shot. First I mirrored the origonal hole pattern measured from lower right side over to the left side. The new hole locations and notching do not compromise strength. Then I notched the lower right corner to clear the ball joint. I notched way more than nessecary.
Old February 23rd, 2004, 08:28 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Thanks JP This is definately what I need...IT will cure my problem. What did you do it the front?
Old February 23rd, 2004, 09:42 AM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
That looks pretty good JP. Looks like I will need one of those also.
Old February 23rd, 2004, 09:44 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chris, I will let you know when I get the CD and send it back ASAP.
Old February 23rd, 2004, 02:59 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chris, just to let you know, I got my hands on a stock d-90 today to check some angles. If you check the front axle from under the rock guard, the axle is at a 16 degree pointed up to the t-case. As for the rear, from under the diff housing, the axle is twisted up 6 degrees.
Now this is a stock rig with no lift at all. Its a good place to start. I am going to set my front up stock without a d-shaft at first and work on the rear till I get no vibes. Then do the front.
Old February 23rd, 2004, 03:50 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Randy, the 2 degrees is what we ususally setup on the rear. When I said 2 degrees in the front, I meant different than the angle of the driveshaft. You want your pinion angle close to the angle of the driveshaft. Sorry about not being clear about that. If you were running 2 degrees in the front, you would probably not be able to get a driveshaft on without having about 3 cv's .
Old February 23rd, 2004, 08:06 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
LOL.. Your right..
Old February 26th, 2004, 10:25 AM
redrover
Guest
Posts: n/a
angles
Hi Randy, I found some angles. In the back the driveline is 2.5 deg difference between the milled flat on bottom of diff and the shaft. My shaft angl is 15deg and the flat is 12.5. I dont know why but the angle finder reads 2 deg different if i turn it around 180-and measure. Measured this way 18deg and 15.5deg. I added a picture of the forward control arm mount. My arms were first generation, and I had to use a washer to prevent arm sucking up into bushing. The Front drive line was measured same way. I have a SG rockguard. the angle of my shaft is the same as the section of the rockguard that bolts into differential. The driveline angle was 18deg.
Old February 26th, 2004, 11:21 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
JP.. Thanks, that really helps a lot. You are running CV shafts front and rear correct? What size are the rims and tires in the pic?
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
D11 front drive shaft jorge Defender Technical Discussions 3 April 12th, 2005 08:03 AM
OME Springs & GBR Drive Shaft J4hand For Sale - Parts 8 January 20th, 2005 10:20 AM
Used rear drive shaft dmarchand For Sale - Parts 0 October 15th, 2004 11:30 AM
New Type of Drive Rear Drive Shaft for D90? DJ Menasco Misc. Chit-Chat 18 July 19th, 2004 06:41 PM
