Drive line stuff... I.e. I'm starting soon - Page 2 - Defender Source
Old September 10th, 2016, 09:06 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Jymmiejamz View Post
That definitely seems abnormal. Maybe try a Genuine U-joint next time and see if it lasts longer.
I'll try anything.
------ Follow up post added September 10th, 2016 10:07 AM ------
Originally Posted by Red90 View Post
You should not use a DC in the rear with only one DC joint. It has parallel flanges and a single DC will cause vibration.
Red was that directed at my post or the OP?
Old September 10th, 2016, 10:05 AM
You said you had a rear DC shaft. If it is DC at one end with a single UJ at the other, it is setup wrong and will vibrate constantly.`If you are going through u-joints with just road use, something is wrong. Without seal failure, u-joints should last forever.
Old September 10th, 2016, 10:49 AM
I've seen aftermarket drive shafts fail in stock Disco 2s in well under a year. I think quality comes in to play here too.
Old September 10th, 2016, 11:48 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I switched from a dc rear to a standard unit, far less vibes
Old September 10th, 2016, 12:26 PM
1of40's Avatar
1of40
1of40
Sorry Red, my bad, I removed the DC and went back to a standard shaft. But with the standard shaft I do seem to go through UJ's too often.
Old September 10th, 2016, 03:31 PM
clay, what angle is your driveshaft and what is your pinion angle relative to the output flange of your tcase?
I had to put a dc shaft on my truck because i was running a twenty degree driveshaft angle relative to the tcase output shaft and the resulting noise/vibration was deafening on my truck.
Old September 10th, 2016, 03:43 PM
1of40's Avatar
1of40
1of40
clay, what angle is your driveshaft and what is your pinion angle relative to the output flange of your tcase? I had to put a dc shaft on my truck because i was running a twenty degree driveshaft angle relative to the tcase output shaft and the resulting noise/vibration was deafening on my truck.
Ed, it has been more years than I can remember and I don't recall what the angle the ds is. Maybe a good task to tackle between beers at kilroys one evening.
Old September 10th, 2016, 04:42 PM
Tom Wood's Custom Drive Shafts - Driveline 101
Old September 10th, 2016, 05:01 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Here's a good video that explains ujoint phasing.
Rent my
Old September 16th, 2016, 05:17 PM
Originally Posted by Rocky View Post
You'll hate me but if the clutch only engages/disengages at the end of the pedal arc it's close to toast.
Vote here is to replace slave, replace clutch and reuse box with fresh fluid. You'll know quickly if you have the same changing issue or not.
Thought I would update the thread...
changed the slave and bleed... short test drive
Seems to be less likely to grind, clutch still engages at floor basically, did and adjustment and pretty much no dice, moving it the middle of the range made it not engage all the way..
I'm thinking I may just change the clutch but that will have to wait till after URE13 right now.
I'm going to rebleed tomorrow and mess around some more but at 150k miles I'm wondering how good it can get, realistically.
So could be interesting
95' D90 - daily driver..
Old September 16th, 2016, 07:21 PM
How far? Probably the muddy campground at URE13.....
Old September 16th, 2016, 07:59 PM
How far can it Go? Dunno... been this way for a couple of years now (Engaging at the floor, i'm an old porsche 911/356 guy and thats what they do) so who knows..
ReBleed is tomorrow and we shall see.. I'm going to do a longish test ride before i do anything else though.
Old November 28th, 2016, 09:04 PM
Getting ready to make the order...
Ashcroft r380 (clutch kit here already)
4.12 R&P (Ashcroft)
F&R Lockers (Ashcroft)
Call it good for 2017
In case anyone was in suspense... 2 loong weekends more wheeling, on it, daily driving it currently while my wife drives the lr3
Back at it dec 9th for another weekend then I'll hopefully be able to get to it (oh and pulling the trailer to camp)
Pretty impressive for a 153k mile clutch
Old November 28th, 2016, 10:24 PM
Are you considering moving to the FTC5200HD throwout bearing? I'm kicking myself for not doing it on the 90, but admittedly I didn't realize they even existed until after I finished my clutch job a couple years ago....
Old November 28th, 2016, 10:27 PM
I have the FTC5200 one - didn't know there was a FTC5200HD at all
it does not come up on LRdirect either, humm
Old November 28th, 2016, 10:36 PM
It's a metal version of the throwout....I got mine from Lucky8. But google it and you'll see, I can also dig mine out (I now have one on the shelf for when mine inevitably fails again) and put it next to my toasted one for comparison pics. But even if you just grab your FTC5200 and *really* look at it you'll be amazed at how shitty it is.
I mean it's no secret how much I hate plastic, and this just furthers that abhorrence .
------ Follow up post added November 28th, 2016 11:38 PM ------
That's a bingo...actually forgot I even posted this thread, but Google found it!
http://www.defendersource.com/forum/...uty-55380.html
Old November 28th, 2016, 10:45 PM
well why not....do it once Right...
got one from paddock spares
Old December 13th, 2016, 10:57 PM
still waiting on the the HD bearing to come in - i need to drop it off and at a minimum do the clutch. i have a normal throwout bearing in stock and the more i think about it the more it seems to be clutch engagement is my core issue (i.e. only OUT at the floor, which when normally driving happens but not enough if you know what i mean)
I'm going to try doing just the clutch - then do the transmission if needed after that - i might have to do it twice in other words.. ideally this will solve 90% of my grinding issues and 100% of my worry about the clutch.
I was off road this weekend and when you smell clutch while its engaged and your foot is no where near it - it's time has come (Plus 156k miles on it is pretty good all in all)
if that plays out then it just lockers and 4.12 gears coming from ashcroft
Old December 14th, 2016, 06:33 AM
1of40's Avatar
1of40
1of40
It may be your flywheel is gummed up with hot spots. Once that's have a good turn things will be sweet again.
Old December 16th, 2016, 05:11 PM
Upon further review, looks like I am adding an LT230 to my list
And dropping lockers for the time being...(too much currently for me to do it all).
It's an evolution...
this will fix the drive line lash I have and upgrade me to the drilled input gear at the same time.
start, starting
New NAS 90 Fuel Line Hoses (Line to Tank) FS SafariHP The Vendors Loft 0 August 28th, 2015 08:36 PM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 08:03 AM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 05:47 AM
Drive Line Vibration reggie Defender Technical Discussions 4 May 12th, 2004 11:27 PM
drive line/OME springs flippedrover Defender Technical Discussions 2 May 3rd, 2004 09:23 PM
