Drive line problems HELP - Defender Source
Old February 17th, 2005, 08:28 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
First off: 1994 defender 90 110,000 miles 2" OME lift.
With that said I had the yoke for my front drive shaft shatter about a month ago. I had the drive line re worked by a specialist and everything has been honky dory untill a week ago. I started to feel mild vibrations, I first thought the drive line was out of wack. But then I was getting off the freeway today and saw smoke, (at first I thought it was the oil cooler lines and almost craped my pants) the smoke was comming off my catalytic converters where the breether tube was dumping gear oil from the front differential. This only happens at freeway speed.
Drive line or do I need new CV's? Can they cause this?
Should I get a double cardon front shaft anyway?
Any suggestions would be great
Thanks for you input in advance!
Steve
Old February 17th, 2005, 08:46 PM
redrover
Guest
Posts: n/a
Seems a little odd that your gear oil doubled in volume and flowed out tube. Have you greased the u joints on the shaft recently? The drive shaft is so close to the cat and the grease can get a little more viscous. Maybe the drive shaft just spun a little excess grease on the cat. JP
Old February 17th, 2005, 08:50 PM
D90user's Avatar
D90user
steve
There is no excess from the u-joints. I don't get it either. you can see where the oil flowed from the breather on to the frame then down on to the cat, the oil came from the breather.
I forgot to mension one point: I just changed the diff oil 2 weeks ago, but I can't see that I skrewed up doing that, Ive done it 1000 tiems before.
Old February 17th, 2005, 09:15 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The only two things that I know of to cause this is the diff overheating (for whatever reason) or there was too much oil in the pumpkin. If you are sure that you did not overfill the front, I would pull it and take a look. It is very wierd that so much came out.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 17th, 2005, 10:19 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Very strange. There's so many sources of leaks under there that I'd check again that it was really from the breather and not an illusion. Power steering hoses, oil hoses, tranny cooler hoses, not to mention pump seals, engine seals, etc, etc. My thoughts.
DW
problems
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
Drive Line Vibration reggie Defender Technical Discussions 4 May 13th, 2004 12:27 AM
drive line/OME springs flippedrover Defender Technical Discussions 2 May 3rd, 2004 10:23 PM
