Drive flange bolt - Defender Source
Old November 15th, 2010, 05:33 PM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
Drive flange bolt
One of my rear drive flange bolts seems to have cracked. the head is gone and I am left with the body of the bolt still threaded in there. Any suggestions on how to remove it?
Help!
Old November 15th, 2010, 05:42 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
If just the head is gone, remove the rest of the bolts and flange, it may be sticking out enough to grab.
If it is stuck in the hub... drill and tap.
Old November 15th, 2010, 06:06 PM
On the t-case end or the diff end? On the T-case end you need to pull the flange to replace the bolt as there is a big C-clip behind the bolts. On the diff end, just take the bolt out and replace it as it is not threaded into the flange or anything like that.
If you are talking about the one in the hub, then good luck getting it out. I ended up just buying a new hub as they are hardened steel and very tough to drill out.
Old November 15th, 2010, 08:33 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
If you are talking about the hub, I removed a hub, drilled out the broken stud on the drill press and had to tap and helicoil it for a repair.
Legend in My Own Mind.
Old November 16th, 2010, 10:46 AM
sirjond's Avatar
sirjond
Jonny
I am talking about the hub...sounds like I am going to be having some fun this weekend.
I am not sure I am capable of doing this. Will see.
Old November 16th, 2010, 01:36 PM
Just buy a used disco I or ABS RRC hub from one of the used parts retailers. You might be able to get it out ok on your own, but I have not had much luck.
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
Muffler Flange Bolt removal Bozman Defender Technical Discussions 2 May 28th, 2009 06:43 PM
Drive flange bolts KevinNY Defender Technical Discussions 6 January 3rd, 2007 10:31 PM
Rear Drive shaft bolt size Buckon37s Defender Technical Discussions 14 October 14th, 2006 04:20 PM
