Dripping LT77 - Defender Source
Old December 11th, 2010, 12:22 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Dripping LT77
Hi all,
There's a bit of transmission fluid dripping down the right side of my LT77 transmission extension case; nothing too horrible yet, but an ounce of prevention blah blah blah. The drips hang on one of the bolts that holds on the cross shaft lever pivot bracket. The only thing I see above that bolt in the service manual that could leak is the breather line, or possibly gear select housing on the top of the transmission. It looks a bit of a tight fit, even if I come through the top. Is there any combination of tools that can be used to check or snug down that line fitting without dropping the transmission?
Right now I'm assuming no sealant was used on the gear select housing gasket, so I should be able to snug that down if I can - please correct me if sealant is normally used.
FYI - The last placed that change the fluid overfilled it. When I checked the level after buying it and driving it 2000 miles, quite a bit of fluid came out when I removed the fill plug. The fluid is now level with the the fill plug hole, and the leak is not as bad but is still there.
Thanks!
LT77 or R380? MAX711 Defender Technical Discussions 3 October 1st, 2010 02:29 PM
LT77 Lay shaft swap between suffixes RollOverRover Defender Technical Discussions 9 August 23rd, 2010 03:14 PM
Lt77 Output shaft replacement Hans Defender Technical Discussions 5 December 9th, 2005 04:33 PM
Lt77 TexasD-90 Defender Technical Discussions 4 November 8th, 2005 04:39 PM
serial # differences from lt85 and lt77 draaronr Defender Technical Discussions 1 August 30th, 2004 11:56 AM
» Defender Registry
Lang
Langley90
D90
NPT90
Add your Defender
