Drilling rear pinion...ok? - Defender Source
Old February 1st, 2012, 06:46 PM
OK, so thank you all for the fuel tank help. It was very...well, helpful for lack of a better phrase
Next question:
I have Randy's RoverBones diff guards coming front and rear.
I would like to install a bolt-on rear pinion guard, such as the rockware:
http://www.expeditionexchange.com/ro...e003%20011.jpg
but the two mounting bolt holes don't exist (yet) on my rear pinion.
I guess my question is, can I drill/tap the holes myself into the pinion? If so, how deep can the holes be before punching into something vital? What is the recommended thread diameter/pitch?
Old February 1st, 2012, 08:50 PM
I've never seen a rover without those holes.
Old February 1st, 2012, 08:57 PM
Oh Philip! Sorry, good point!
I forgot that my Defender's rear comes from a range rover classic. I'm not sure if that makes a difference.
But really it doesn't have the holes.
Old February 1st, 2012, 09:36 PM
Is this a trick question Ed? Just weld a piece of plate on and be done! It's not like you can't replace the pinion housing one day if needed, or cut it off.
Originally Posted by pendy
I'm here for the D's
Old February 1st, 2012, 09:59 PM
Are you sure they're not just packed with muck? Mine were...thought the same thing for a bit until I took a pick and scraped them out.
Old February 2nd, 2012, 09:35 AM
hmm...good point, let me poke up there jason.
Old February 2nd, 2012, 09:48 AM
If you really don't have the holes and you really want to bolt on a pinion guard, I can measure the depth on one here. I'd go with any standard size thread as the rover one is some non-standard size.
Truck running yet?
Old February 2nd, 2012, 09:53 AM
Yeah those threads are some fucked up british thread
Old February 2nd, 2012, 10:01 AM
Whitworth?
Like the F'd up british truck we drive ...
Old February 2nd, 2012, 10:18 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
FWIW I re-tapped mine to 3/8-16 and haven't had any problems
Old February 2nd, 2012, 10:28 AM
That is because you have never owned a Rover made before the 1980's.
Old February 2nd, 2012, 03:30 PM
Truck is definitely not up and running yet due to the fuel tank sitting in my bathtub.
Need to derust and paint before replacing.
Old February 2nd, 2012, 03:36 PM
Oy. So WTF are you thinking about a pinion guard you don't need!
Old February 2nd, 2012, 03:37 PM
Because I'll need it once the diff guards come in!
Old February 2nd, 2012, 03:38 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
he's planning his reason why the truck won't be driveable til the fall!
Old February 2nd, 2012, 03:47 PM
No you wont - they are unrelated. Weld on the diff guards (5 mins) and skip the pinion guard. Drive your truck before worrying about it - i doubt you'll ever be in a position where you wished you had them, but if you ever do, then would be the time to add them
Old February 4th, 2012, 03:49 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Hey at the rate you're going the truck will be so shiny that you'll never off road it.
What do you need a rear pinion guard for anyway? If you're going forward the front axle of the truck will wipe out any bad stuff!
Front and rear diff pan protection - that's a good idea
Mike Hammond
rear pinion angle correction KevinNY Defender Technical Discussions 11 April 6th, 2007 03:35 PM
Rear Pinion slack flippedrover Defender Technical Discussions 4 September 12th, 2005 10:07 PM
Rear Pinion flippedrover Defender Technical Discussions 13 August 14th, 2005 08:43 PM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
