Drilling holes for rear light guards - Defender Source
Old December 30th, 2004, 05:03 PM
khatadin
Reed/Scott
I am about to attach rear light guards to my d-90. Is there anything I should know about drilling the holes in the exterior panels before I start? For example, should I prepare the metal by tapping it first? or just line up the holes and start drilling with an appropriately sized metal bit.
Lastly, once the holes are drilled, should I apply some sort of subtance on the bolts to help prevent rust? thanks.
-Scott
Old December 30th, 2004, 05:59 PM
I measured about 20 times before I drilled anything.
I then put masking tape over where I was going to drill.
I then marked the masking tape and hit each mark with a punch (You don't want your drill bit walking across your paint)
I then drilled a pilot hole with a small bit. Then drilled them to size with a larger bit.
It helps to have second person “eyeball” things for you while you hold the guards in place. I didn't coat the exposed metal with anything but if I lived in snow country I would shoot the back of the nuts with paint or undercoating (not my area of expertise, I live in Phoenix).
Old December 31st, 2004, 09:16 AM
khatadin
Reed/Scott
thanks..exactly what i was looking for. -Scott
Old January 4th, 2005, 12:07 PM
popeohana's Avatar
popeohana
Jeremy
94 Arles ST
I just drilled holes in my 90 to install a rear seat. Any suggestions on what product(s) are available to treat the holes for rust prevention.
Old January 4th, 2005, 12:44 PM
khatadin
Reed/Scott
I was given the following advice, which may apply to your situation as well.
"if you can get to the thread I would coat with rust proof compound, or anti-rust paint/primer.(once installed of course) if you should judge that no access to the bolt threads is possible once installed, i would consider using antiseize compound on the threads prior to installation."
Separetely, any advice on the type of drill bit that works well?
Old January 4th, 2005, 12:53 PM
I second Anti Sieze! That stuff is great! I use it on almost everything. You could try and get a reverse drill bit, they will try and back out the bolt like an easy out will.
Old January 4th, 2005, 09:21 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Scott,
I like to use a planing bit...instead of a tapered point it has a small point in the middle to center and cuts more like a small hole saw...makes perfect holes with little cleanup required and doesn't chew up the aluminum. Also, after installing several sets of light guards and wing protectors I quit trying to fit the nuts on the back and started installing threaded inserts in the body instead. This is much easier. Take a look at where they expect you to fit the nuts (and your fingers) before you drill...
Rob
Old January 5th, 2005, 10:23 AM
khatadin
Reed/Scott
Rob, thanks. Dumb question, but are planing bits and threaded inserts relatively easy to locate at hardware stores? Or is there somewhere else I should look?
thanks again
Old January 5th, 2005, 08:43 PM
Roadsiderob
Robert Dassler
1994 D90
Scott,
The bits will be available at the hardware or home store...Black & Decker, Snap on and others make them. The 6mm x 1.0mm threaded inserts (Riv-Nuts) are a specialty item. I would look for them at an industrial fastener store or try Wurth. You will need to either make or buy an installation tool as well. To make one, take a piece of flat steel 1/8" x 1" x 6" and drill a hole in one end big enough for a 6mm bolt to fit through. Get a 6mm bolt about 25mm -30mm long and thread a 6mm nut all the way up to the head of the bolt. Put the bolt/nut through the hole in the flat steel and then thread the insert on until the bolt is flush or a little past the end. Put the insert into the prepared hole and tighten the nut down onto the flat steel while holding the bolt and the flat steel stationary. Further tighten the nut to expand the body of the insert in the hole. I'd get a few extra and do one on some scrap for practice to judge the feel of it so you know when to stop expanding the insert...you can damage them if you go too far. Inserts are available in either steel or aluminum...I'd use the aluminum ones for lamp guards or wing protectors and go with steel for more structural applications such as holding a hardtop in place.
Rob
guards, ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
'94 Tail Light Guards and Misc Roll Cage parts For Sale PCRover For Sale - Parts 6 September 24th, 2008 01:37 PM
Rear lamp guards (tail light) mod4b Wanted 1 August 2nd, 2005 05:06 PM
Genuine Brush bar - Light Guards Kimos Wanted 0 December 2nd, 2004 11:47 AM
tail light guards ronward Wanted 3 April 5th, 2004 11:14 AM
