Drilling frame help - Page 2 - Defender Source
Old October 30th, 2015, 02:15 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Originally Posted by Ren Ching View Post
I wonder if perhaps you have it set up wrong. Usually thise things borrow an existing bolt hole. In any event, if you can't use an existing hole, install a riv nut in the side of the chassis. A fine thread sheet metal screw would work too but the riv nut would be a little better. The only stress on those fasteners will be from vibration or if you whack the step on a rock or tree stump.
Pete, I don't believe these sidesteps were specific for the NAS model and require drilling.
Drilling rear pinion...ok? sonoronos Defender Technical Discussions 16 February 4th, 2012 03:49 PM
Prefered method for drilling holes in the body cabell Defender Technical Discussions 8 November 4th, 2010 11:00 PM
Drilling out rivets aosias Defender Technical Discussions 9 March 12th, 2010 06:49 PM
re-drilling the swivel balls slorocco Truck Build-up's & Restores 15 November 17th, 2008 11:44 AM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
