Draining Radiator - Defender Source
Old November 4th, 2004, 10:16 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Draining Radiator
Didn't find anything in the FAQ's or a search.
Going to drain the radiator to replace my heater pipes. The manual states to remove the viscous assembly. Only problem is that it requires the LR special tools. Is this step necessary to drain the radiator properly? Seems like a step designed to provide access and to inspect the viscous coupling by the dealer. I assume that I can just drop the lower hose per the manual?
EwS
Old November 4th, 2004, 10:23 AM
well there is an easier way to drain the radiator, I stick a small hose down into the top fill plug on the radiator and siphon out the fluid. Get about 4 feet of 3/8 I think OD clear flexible tubing (Home depot has it in the plumbing section), stick it as far into the radiator as you can, then suck the air out holding the hose lower then the radiator. I drain it into empty bottles. This is a very clean and safe way to get the antifreeze out, as you may know it is very sweet tasting so animals like to drink it, but it will kill them in no time if they do drink it. So if you spill any be sure to dilute it with a lot of water.
Old November 4th, 2004, 10:42 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Very cool. Thanks.
EwS
Old November 6th, 2004, 02:34 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Exactly what I was going to suggest...
Mike Hammond
Old November 6th, 2004, 05:49 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I use a kerosene squeeze pump! 2 dollars at ace! No sweet taste in the mouth!!!!!!!! has a long inlet to go into rad & fits most of the way down. cleen & easy!
drain, radiator
Radiator crobinson For Sale - Parts 4 February 14th, 2006 10:51 PM
leaky/bad '97 D90 Radiator kiphartzell Wanted 8 April 11th, 2005 03:42 PM
Radiator Decal Question 48vphantom Defender Technical Discussions 3 January 31st, 2005 09:42 AM
Genuine LR Defender radiator crobinson For Sale - Parts 2 August 11th, 2004 10:24 PM
Radiator flippedrover Wanted 7 April 26th, 2004 09:50 AM
