Drain Plug Diffs/Xfer Case - Defender Source
Old October 31st, 2009, 07:36 PM
Grover's Avatar
Grover
Question Drain Plug Diffs/Xfer Case
Are the front/rear diff drain plugs the same size/thread as the transfer case drain plug? I want to replace all three with a magnetic drain plug FTC5208G from AB.
Cheers...
Old November 2nd, 2009, 12:23 PM
Grover's Avatar
Grover
Bumpity bump...
Old November 2nd, 2009, 01:39 PM
T-box is different
Originally Posted by Grover
Bumpity bump...
Old November 10th, 2009, 07:20 PM
Grover's Avatar
Grover
Smile
Finally got a round tuit...
The front/rear diff and the LT230 drain plugs are the same...
Old November 11th, 2009, 02:56 PM
That is what I thought, but I did not want to contradict DB without being sure.
Old November 11th, 2009, 08:18 PM
hmm. guess I'll have to hve another look. i thought the lt230 used a hex head plug with a copper washer.
Old November 11th, 2009, 09:52 PM
Grover's Avatar
Grover
hmm...not sure...
Are there different designs/versions of the LT230? IIR I read somewhere about LT230Q and LT230R boxes...
Cheers...
Old November 11th, 2009, 11:21 PM
It is the fill plug that is the same as the drain on the diffs. The drain is a short bolt as DB says.
diffs, drain, drain plug, fs
transmission drain and fill rover4x4 Defender Technical Discussions 24 November 16th, 2011 02:31 PM
Transfer Case Filler Plug removal d90xjay Defender Technical Discussions 19 December 29th, 2009 12:56 PM
where is drain plug for the swivel housing UpnOver Defender Technical Discussions 10 July 23rd, 2007 03:23 PM
Oil pan drain plug thread Pat Defender Technical Discussions 0 June 23rd, 2006 09:02 AM
what does this plug in to? mattdh Defender Technical Discussions 6 November 2nd, 2004 11:59 PM
