dragging brakes lr90 - Defender Source
Old May 5th, 2014, 10:27 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
'85 lr90 2.5NA
Experiences? Hints? Before I start disassembling things.
I replaced the brake m/c (TRW), servo and stop light switch, the m/c was a bit soft and the servo was a case of 'while I have the tower off'. The pressure bleed went fine but the brakes are dragging a bit, getting worse after a few miles leading to that familiar smell and feel. The pedal seems to grab higher and is more touchy than before. The brakes get hot, but not blistering and smoking as I've seen, but I have not driven her more that a few town miles at a time since the work.
I am leaning towards the servo push rod being set a bit long holding some brake pressure, but if that is the case, how would the bleed have worked? Or the new switch installed too far holding the pedal slightly off the stop as I noticed that after a point the switch went in further but the stop light switch-on point remain unchanged. I backed it off two turns, but have not driven it yet.
Thank you.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
90, brake
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
Brakes dragging cgalpin Series Technical Discussions 20 April 22nd, 2012 05:13 PM
Refurbished 1984 LR90 Station Wagon globallandrovers The Vendors Loft 2 January 28th, 2009 04:28 AM
New ECR Defender version.. the LR90 ECR Misc. Chit-Chat 12 December 20th, 2007 11:10 AM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
