Drag link position - Defender Source
Old May 22nd, 2011, 10:05 PM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Drag link position
My 110's drag link is always bent backwards, such that the balljoint bangs against the drop arm edge. It seems that it should be straight-ish up and down, but it never is. The first picture is what I think it should look like, while the second is what it how it actually sits all the time. I suspect that this may also be causing the constant disintegration of the ball joint boot. Is this normal? Is this b/c I stupidly put in a Bilstein damper?
ID:	39003   Click image for larger version
Old May 24th, 2011, 11:23 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Adjust the other end so they're both centered, should sort it. If the TRE's are in good shape, the steering damper won't push them over.
Tony
1984 110 "Smokey" (sold)
Old May 26th, 2011, 11:29 AM
piekas's Avatar
piekas
Pierre Jourda
1987 Defender 110
Thanks, I'll try this
Old May 26th, 2011, 11:34 AM
You need to replace or rebuild that drop arm ball joint ASAP as the boot is shot to hell!
Unsafe as it is.
Old May 26th, 2011, 03:38 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
agreed..has nothing to do with the new damper, you need to thoroughly check that ball joint ASAP, that could be hanging on by a thread, almost looks like the rubber is holding it together..
I wonder if I can drive over that..?
Old May 26th, 2011, 04:39 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Let's not let the drama get away from us here. The drop arm ball joint rarely fails catastrophically, it just gets sloppy as hell and makes the steering loose.
Tony
Old May 26th, 2011, 07:47 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
My boot just broke apart and I want to deal with it.. I've got a new drop arm that I'd like to throw in vs. doing the rebuild.. can I do this on level ground without removing a wheel, having to adjust the steering box, etc? Or am I deluding myself?
-Ren Ching
Old May 27th, 2011, 05:21 AM
TS888's Avatar
TS888
Tony Sims
1984 110
If you're going to the effort of removing the drop arm (heat, BFH and an angle grinder highly recommended), might as well swap the the RRC/Disco version and be done with the ball joint for all time. TRE's are much easier to change.
Tony
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
FS: HD Defender Drag Link DarrinK For Sale - Parts 2 April 16th, 2011 12:39 PM
Rovertym stainless steel drag link 64rovr For Sale - Parts 7 February 2nd, 2011 07:46 AM
Which linkage is the Drag Link little black duck Defender Technical Discussions 3 October 22nd, 2006 11:31 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
