Drag Link- is it slightly bowed? - Defender Source
Old July 13th, 2013, 02:44 PM
hankhowi
s
1997 Defender
This might be a silly question, but does the drag link come from the factory with a very slight bow (bend) to it ? I suspect I might have a bent drag link, not sure if this how it was designed with a bow.
Old July 13th, 2013, 03:00 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Should not be bent. You can have a local 4x4 shop make you a new HD one. I had one made for around $100 out of thicker walled DOM tubing.
Old July 13th, 2013, 08:52 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The stock ones are hollow tube and do get bent quite easy. I haven't seen one you could fix. If the bend isn't too bad you can still run with it but will need to check your toe adjustment as the bend will have made you more toe out.
Old July 13th, 2013, 09:10 PM
hankhowi
s
1997 Defender
Thanks for the information. I went ahead and bought the upgraded aftermarket version from Rockware....
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
FS: HD Defender Drag Link DarrinK For Sale - Parts 2 April 16th, 2011 12:39 PM
Rovertym stainless steel drag link 64rovr For Sale - Parts 7 February 2nd, 2011 07:46 AM
Which linkage is the Drag Link little black duck Defender Technical Discussions 3 October 22nd, 2006 11:31 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
