downward travel - Page 2 - Defender Source
Old November 28th, 2012, 06:34 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Originally Posted by Wolf Fabrication View Post
I think you need something to limit downward travel besides the shock itself.
The front hockey stick chassis bush binding that'll do it
Mike Hammond
Old November 28th, 2012, 06:55 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Are you worried the shock cannot hold the weight? I would be more worried about uptravel as that is how you can mess up a shock or shock tower in a hurry
Old November 28th, 2012, 11:39 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Originally Posted by jefhuf View Post
Why bother putting on longer shocks if you are going to limit articulation?
Clarification, articulation is limited only at the front with standard shocks for a 2 inch lift and straps. The rear is allowed to articulate as much as possible with longer shocks and raised upper shock mounts. All the springs are are mounted with retainers.
"I think you need a little weatherstripping - right here..."
Old November 29th, 2012, 12:09 AM
CDeWan
Clay DeWan
5.3L beastie
body roll
Thanks guys for your input. So if you let limitless travel (un retained) and no front rollbar aren't you running a risk of roll over?
I think my takeaway for piece of mind is that I am going to run a limiting strap up front...I just do not feel like f(**(g with the dislocation cones up front as it nearly wiped out 2 days installing the shocks as I was missing a few parts.
I will eventually get around to putting the front cones on .
Also as I side note, if anyone is thinking about running straps, they do stretch. So the limit that you started off with, may not be what you end up with after awhile
Old November 29th, 2012, 02:36 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Yea I have read online to add up to an inch for stretch on limiting straps. I must say I find it straight that the stock rover suspension is limited by the shocks so what does changing the length of the shock do? I guess the only reason I am going to run limiting straps on the rear is because the flex with those arms is out of control!!
Old November 30th, 2012, 12:39 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Not a good idea to rely on shocks to limit axle travel....
7100's remote. res, short body, 12" travel Capt Milks Wanted 1 October 29th, 2012 08:50 AM
Bilstein 7100 shock travel question Tyler Wirken Defender Technical Discussions 6 August 5th, 2012 02:06 PM
Desert Rover Rear Long Travel Shock Kit kiphartzell Wanted 0 March 17th, 2005 10:21 AM
On-line travel booking? chrisvonc Misc. Chit-Chat 5 September 25th, 2004 03:05 AM
Stock hight with more downward travel flippedrover Misc. Chit-Chat 15 February 27th, 2004 11:25 AM
