doors won't open - Defender Source
Old November 26th, 2008, 09:52 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
doors won't open
Ok, so this seems simple but it has become a pain. The two rear doors on my 110 wont open using the door handle on the outside nor inside, the locking mechanism seems to function. With the door panel pealed back as far as I can get it without breaking anything, it looks like the inside handle linkage is connected and working; I can see how the lock prevents it from moving when locked. I cannot for the life of me figure out why it woun't release the catch. I am open to any ideas...taking the door off the hinges is not a good one I tried that already.
Tis
Old November 26th, 2008, 10:13 PM
madcowdungbeetle
Carter
You'll probably have to pull the door card off, and adjust the linkage. I don't have any experience with the SW style D90 doors, but if they're anything like the ones in my Disco, just the slightest adjustment, like half a thread, to the linkage that engages the latch is all it takes to get the door latch to work again.
Old November 26th, 2008, 10:23 PM
How bad are they rusted? When they rust in the right spot, the linkage won't actuate with either the handle and will simply re-lock. Try rolling down the window, holding the lock button up, and using the outside handle to open the door...
Old November 26th, 2008, 11:05 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
Rusted bad enough that when I pull hard on the inside door handle I can see the lock mechanism flex and pull towards the handle.
I have tried that combo and even tried to hold my mouth just right.
Old November 26th, 2008, 11:57 PM
Hmm, sucko. That combo move is what finally worked for me, and now I can open and close the door pretty reliably using only the exterior handle. Doesn't really matter though, the truck is such trash that there is no point in driving it. I've got a salvageable set of doors and I'll just keep collecting parts until I can get some time this summer to work on the truck.
Old November 27th, 2008, 01:26 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
Long flat head screw driver did the trick. Leverage the striker assembly inward and slide the thin flathead further in and lift the catch just a bit. One hour spent on it last night in total frustration, 5 minutes this morning and it popped free...rovers.
door
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
Interior Lights when doors are open bjf Defender Technical Discussions 8 July 1st, 2009 11:30 AM
Switch from ST doors to SW doors TAIIISI Defender Technical Discussions 5 August 29th, 2005 12:27 PM
Defender Doors and Door Tops Buckon37s For Sale - Parts 5 June 12th, 2005 06:14 PM
» Defender Registry
Tina
UtahD90
Kermode
StuartL
Add your Defender
