doors - Defender Source
Old June 18th, 2004, 12:26 AM
redrover
Guest
Posts: n/a
doors
has anyone pulled their doors off? My question is - do the phillips/bolts have a backing plate or just nuts. Can you just remove bolts or do you have to get inside backing area to reinstall? And why hasnt anyone machined a stock looking hinge, that works like the jeep harddoors? JP
Old June 18th, 2004, 04:24 AM
Oggy's Avatar
Oggy
OGGY
1984 LR 90 200Tdi
Bolts go into captive pair of nuts inside bulkhead.
Easy to take off / change bolts or hinges.
You might find it a bit of a B*****D to re aline the door. Note position of door and hinge before dismantling with some refrence markings with a felt pen so that you can get it back to the same point when rebuilding.
Old June 18th, 2004, 08:21 AM
I take the doors off all summer, I don't have any problem realigning them, I just put the bolts on but don't snug them up, then I close the door and tighten them up and the doors are allied! The trick though is to leave the bottom hinge on the door and the top hinge on your 90. Then use a 3 strip of 1 wide strip of aluminum to hold the hinge closed. Drill a hole in the aluminum for the bolt on the door side of the hinge. It is hard to explain I can take a pic later.
Old June 18th, 2004, 08:33 AM
Ntajeep
Matthew Bremner
1997 AA Yellow D90
Some peope have just taken the bolt out of the hinge completely and dropped a cotter pin or similar into it, so it is just like the jeep doors. I, although, have not had the balls to try that one, plus it only takes about 10 minutes to get each door off i f you have a #3 Screwdriver or ? # Torx driver. Make sure you are careful when unscrewing them because the first time I took mine off the captive bracket decided to spin and that door was not coming off until I went to the dealership for it to be fixed. (Expensive!).
-Matt
Too rainy in Indianapolis to take the doors off right now.
door
Switch from ST doors to SW doors TAIIISI Defender Technical Discussions 5 August 29th, 2005 12:27 PM
Defender Doors and Door Tops Buckon37s For Sale - Parts 5 June 12th, 2005 06:14 PM
Switch-out HT Doors w/ ST Doors 1of40 Defender Technical Discussions 11 May 2nd, 2005 09:04 PM
Looking for SW front doors kellymoe Wanted 0 December 6th, 2004 11:44 PM
Newer doors Disco_Stu Defender Technical Discussions 3 February 26th, 2004 03:07 AM
