Door won't open from inside - Defender Source
Old January 13th, 2013, 06:49 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Just a few weeks ago my left hand front door stopped opening from the inside. On any other door there are two 'clicks' of the latch as you pull back the handle. On the passenger side it only reaches the first 'click'. I pulled off the door card and the cam that presses open the door latch actuator just isn't pushing down far enough. I can push down the actuator with the end of a socket and it opens the latch all the way. I looked for a way to shorten the rod that connects to the cam but I couldn't see any adjustment point.
ANyone dealt with this issue before? Any advice? Thanks.
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old January 13th, 2013, 06:52 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Is the plastic piece still on the "catch". If it is not the diameter of the catch is reduced and sometimes will not engage the second click...
Old January 13th, 2013, 06:59 PM
ontheway's Avatar
ontheway
Dave
No plastic anywhere - all metal to metal contact.
Old January 13th, 2013, 07:07 PM
tjfslaughter
thomas
Burbon
Check the other good doors. There should be a piece of plastic on the catch assembly. If you are missing that it could be your issue.
------ Follow up post added January 13th, 2013 07:07 PM ------
Push button or lift up?
Old January 13th, 2013, 07:08 PM
ontheway's Avatar
ontheway
Dave
lift up style doors
Old January 13th, 2013, 07:10 PM
tjfslaughter
thomas
Burbon
Originally Posted by ontheway View Post
lift up style doors
Sorry. I don't have experience with those. On push button if you don't have the plastic "shim" you will have the symptoms. The plastic adds about a 1/16" which when removed will cause similar issues.
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I had the same problem on my 110 both doors quit opening from the inside. I found a slight adjustment of the linkage from the handle to the latch got it working again.
Unknown Author
716-898-8153
Old January 13th, 2013, 07:30 PM
ontheway's Avatar
ontheway
Dave
What linkage specifically? The long linkage between the handle and latch?
Old January 13th, 2013, 08:17 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
That was the one, I put a "slight bend" in the rod and that shortened it just enough.
Unknown Author
716-898-8153
Old January 13th, 2013, 08:23 PM
ontheway's Avatar
ontheway
Dave
Ok thanks! - I'll try to modify it somehow tomorrow.
door
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
Inside Door Panel Reinforceing The Wizard Defender Technical Discussions 30 November 15th, 2006 05:03 PM
Thermostat Stuck Open? johare Defender Technical Discussions 12 March 16th, 2006 08:58 AM
OT: NASA's JPL Open House - This weekend, May 14-15, 2005 arbik Misc. Chit-Chat 0 May 13th, 2005 06:47 PM
Inside door storage bags Campbell Wanted 0 March 13th, 2004 10:17 AM
