door top studs - Defender Source
Old April 23rd, 2009, 06:24 PM
Gibson04
Justin Church
1994 D90 / '04 Disco
door top studs
Whats the trick to remove the factory studs in the door tops? i cannot remove them for the life of me. please help
Justin
Old April 23rd, 2009, 06:27 PM
Where are they stuck? In the door or in the top?
Old April 23rd, 2009, 07:39 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Are you talking about the studs that hold the windows in place? If they are stuck with the windows in place on the door...
If so there is a special tool I think. But I just used a bike wrench, worked like a charm.
Old April 23rd, 2009, 07:48 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
DO NOT ... I REPEAT ... DO NOT ... even lightly, tap on the bottom of the studs with a soft dead blow hammer without removing your glass.
If you do not heed my warning, wear eye and ear protection!! (I speak from experience!)
Dendy
Old April 23rd, 2009, 08:08 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
Justin
Whatever tool you end up using take extra care not to hit the door skin.. one wack with a wrench and you'll have a nice bump on the top of the door.. the studs are dangerously close to the skin...
It also a good idea to replace them with stainless...
Old April 23rd, 2009, 09:47 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Kroil and the biggest vice grips you have.
Old April 23rd, 2009, 10:36 PM
If they are stuck in the doors, just put two nuts on the bottom of the stud and spin the top nut while holding the lower nut tight.
Old April 24th, 2009, 10:44 AM
Gibson04
Justin Church
I have had them off the doors for the last year and I need to replace the rusty studs. I have tried to wrench the studs out of the door tops with Channel locks, vice grips and pliers.....but have not been able to remove them......they are threaded in the standard direction of right tighty lefty loosey right?
Old April 24th, 2009, 10:52 AM
Standard direction. Use the two nuts trick I posted above.
Old April 24th, 2009, 12:25 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Two nuts and Kroll
Old April 24th, 2009, 01:01 PM
dbj2003
Brandon Jones
94 Defender 90 POE
Locking wrench (like the one below) and break free. Just went through this last fall.
http://irwin.com/irwin/consumer/images/small/4lw_sm.jpg
Old April 24th, 2009, 02:11 PM
Gibson04
Justin Church
thanks guys.....will try the two nut trick (no jokes) and if i cant get that to work i will buy a locking wrench.
door
stainless window studs mattdh Defender Technical Discussions 34 December 9th, 2005 08:19 PM
USED defender window studs on ebay eric_besore For Sale - Parts 10 September 3rd, 2005 01:13 AM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Gulf Coast Rover Window Studs DiscoDino Defender Technical Discussions 6 December 21st, 2004 01:29 AM
SS Window Studs? bugula Defender Technical Discussions 6 May 17th, 2004 04:47 PM
