Door Top Stud Water Leak? - Defender Source
Old May 21st, 2011, 09:28 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
The Door Tops on my D-90 leak. It appears that water is coming in through the door top stud holes. I converted to the stainless studs and quick nuts last year and I am wondering if there should be some kind of seal between the door top stud and the door mounting holes. Right now, There seems to be a lot of space for water to get in.
My door seals are fine and water is draining out the channels as it should but way too much water is dripping inside through the stud holes. What should be there to stop the leaking?
Thanks!
Old May 22nd, 2011, 01:22 AM
Grover's Avatar
Grover
Here is my post on the matter:
http://www.defendersource.com/forum/...1&postcount=19
Hope this helps...
Cheers...
Old May 22nd, 2011, 09:02 AM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
Thanks. I had checked out your post. I'm curious about the cut stud washers. I currently have no washers on my door studs. I'm trying to imagine where these go? Do you have a pic of the washers installed or can you give me a better idea on where they go? Also, where did you get the rubber washers for the studs?
Thanks!
Old May 22nd, 2011, 01:50 PM
Grover's Avatar
Grover
Thanks!
The cut washer goes between the stud nut and the door.
The rubber grommets were sourced at a hardware store.
Cheers...
Old May 22nd, 2011, 02:45 PM
timtimtj's Avatar
timtimtj
Tim Blanco
1994 Defender 90
I see. I'm using the quick nuts so perhaps that's why indoor have the washers?
Old May 22nd, 2011, 08:08 PM
Grover's Avatar
Grover
The reason for the split washers is to allow for drainage if water gets past the seals. Without drainage, water pools inside the bores and...well you know the rest of the story...
Cheers...
door, water
AC water leak 89classic Defender Technical Discussions 2 June 12th, 2005 01:21 AM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
