Door Stay Pickle - Defender Source
Old January 16th, 2016, 01:37 PM
Matt_110's Avatar
Matt_110
Matt
110
Door Stay Pickle
I've been trying to find the correct door catch/stay for a while. My issue is that I have Puma doors on an 87 110.
This is what I have left from my original second row doors.
Any idea on part numbers and source? I don't want to revert to the old canvas strap workaround I had before. Thanks!
1987 110, 2.8TGV, ZF Auto
Old January 16th, 2016, 02:14 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
BFH710140 and BFH710150 would be what you're looking for.
EDIT: It also appears you're missing the torsion catch which holds the door open. BFU710200 (x2), MWC6450 (x2) and ALR2318 (RH) and ALR2319 (LH) will get you sorted.
-Ash
Geared Restoration Co.
352-572-3236
Old January 16th, 2016, 02:43 PM
Matt_110's Avatar
Matt_110
Matt
110
Originally Posted by Ash View Post
BFH710140 and BFH710150 would be what you're looking for. EDIT: It also appears you're missing the torsion catch which holds the door open. BFU710200 (x2), MWC6450 (x2) and ALR2318 (RH) and ALR2319 (LH) will get you sorted. -Ash
Ash you're a savior. Thanks man. Will get these ordered finally.
Old January 24th, 2016, 09:04 AM
Matt_110's Avatar
Matt_110
Matt
110
Ash, do you know if the door catch channel is the same on newer doors? I have puma doors and my original channel, but it just doesn't seem right at all. The check strap runs out of room and falls out the channel when I shut the door.
Old January 24th, 2016, 12:34 PM
Matt_110's Avatar
Matt_110
Matt
110
Sorted! I got a call from Rovers North today (thought they would've been closed on Sunday) in reference to a recent order. Rob was great and found the exact part I needed. Click image for larger version
ID:	140283 #19: I'll add the part number once it arrives in case anyone needs it in the future.
Defender rear door stay / check jafir Wanted 25 January 28th, 2015 06:08 PM
WTB Drivers side seat belt.& door stay Hammertime Wanted 0 December 7th, 2014 06:15 PM
Door wont stay shut or locked Howski Defender Technical Discussions 5 May 4th, 2014 07:22 AM
Door won't stay unlocked. Paul K Defender Technical Discussions 4 December 26th, 2013 07:29 PM
Iron goat door trim & door stay CDNRover Defender Technical Discussions 0 December 6th, 2012 03:37 PM
