door seals for ST w/ FG Hardtop - Defender Source
Old February 22nd, 2009, 11:13 AM
are they all the same?
i see the ones for the SW but no listing for the ST.
My truck as the LR Hardtop on it right now.
Also any Tips on isntallation.
lots of little things to do on it but generally in goods shape.
95' D90 - daily driver..
Old February 22nd, 2009, 11:31 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Robert,
I believe they are the same, mine are installed in the door opening...start at the bottom "grove" to include the hardtop..all the way around the door opening.
Old February 22nd, 2009, 07:31 PM
I have seen two types used with the fiberglass top. The standard SW style and individual pieces for the top and back.
Old February 22nd, 2009, 08:10 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
I used the same ones as I use in the lower doors. they were interchangeable,
Old February 22nd, 2009, 08:20 PM
I just used the standard station wagon seals, they're the same. You need to start installing at the top since the top corners are molded into the part and need to be in the right place (they're also "handed" right and left). Sometimes there is bad alignment between the flange on the body and the flange on the top at the rear edge of the door. You can fudge this wee bit by bending the flange on the body a little bit. Obviously its best to try and align the top first, but you dont have much play there.
Old February 22nd, 2009, 11:34 PM
looks like the Sw seals are the winners here. I'll order up a set and give them a go if the set i have does not work out. I did get a set with the truck but they were not stored very well and are bent in intersting ways.
Old February 23rd, 2009, 07:07 AM
The tops came with SW seals as standard (I had a new top at one time). You do have to be careful bending them for them to store properly. I've kept the original seal box and thats what I keep all my seals in now.
door, hardtop, seals
where to get SEALASTIC for NAS hardtop install? psolvik Defender Technical Discussions 4 October 10th, 2009 04:48 PM
Fiberglass Hardtop for Sale boshea For Sale - Parts 3 October 19th, 2005 08:18 PM
Looking for a Hardtop???? adibitar Wanted 2 July 11th, 2005 12:48 AM
Help with installing hardtop Chris Cox Defender Technical Discussions 4 November 24th, 2004 04:56 PM
rhino lining for fiberglass hardtop CHRIS C Defender Technical Discussions 7 March 28th, 2004 10:47 PM
