Door seals and top removal - Defender Source
Old July 7th, 2014, 03:29 PM
slacker
don slack
1986 ex mod 110
Hi all, another top question from a newbie. Have an 86 ex MOD with Tithonus cage and hard top. Want to take top off for summer. Looks like I will have to cut the door seals at the windshield and top of the tub to separate the top from the truck. Do I have this wrong? Will I regret it in 3 months when the Washington rains begin? Thanks!
Old July 7th, 2014, 03:36 PM
Why don't you just remove the door seals all together for the summer? In the winter you can re-install the door seals when you re-install the top.
Old July 7th, 2014, 03:51 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Don,
No need to cut anything to get the Tithonus hard top off. We've got a couple local Tith owners working on a custom soft top solution and have pulled the fiberglass top off before. Happy to walk you through it if you wanted to make the trip down to Gig Harbor. Jimmy is correct in that you can pull the seals off completely, or if you plan to run "topless" for a while a second set of seals made for the purpose would be a bit nicer.
Old July 8th, 2014, 01:18 AM
slacker
don slack
1986 ex mod 110
Geez, why didn't I think of that. Top is off, seals are saved. I would like to know more about a soft top for a Tithonus. Now to find a tailgate... Thanks all
Old July 8th, 2014, 08:21 AM
LRover's Avatar
LRover
J. Michael McCaig
I got tired of my doors rattling when I had the top off my D90 so I got some door seals from a wrecked Disco that I didn't mind cutting and used those saving the original seals for when the top was back on. Just a suggestion...
Old July 8th, 2014, 08:26 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
PM sent
door, seals, top
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
TD5 bulkhead vent seals vs. NAS seals Tyler Wirken Defender Technical Discussions 11 March 14th, 2011 10:22 PM
Door top seals JBfoot Defender Technical Discussions 4 August 30th, 2007 10:47 PM
Need set of good soft top door seals shawnpalmer Wanted 0 March 11th, 2007 11:41 AM
••••Fiberglass Hard Top with all hardware and door seals••••• JAD For Sale - Parts 12 February 26th, 2007 08:05 AM
