Door seal issue - Defender Source
Old July 27th, 2016, 02:20 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Tying to determine if this gap in the door seal lip between the windscreen and the bulkhead is normal. When it rains the water runs down the outside of the seal, crosses over at the gap and then drips off the door catch onto the floor. The door seals are new so not sure how to prevent this. Any wisdom is appreciated!
Old July 27th, 2016, 02:38 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I siliconed mine no leaks
Old July 27th, 2016, 02:39 PM
A tube of clear silicone is a Defender's friend....
Old July 27th, 2016, 08:02 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The factory used a type of putty and tape. Your rubber seal should cover most of it up.
Land Rover 110
Old July 27th, 2016, 08:08 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Yup. Standard from the factory is cloth tape over top of DumDum (Butyl sealant)
Old July 28th, 2016, 09:55 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Thanks, that's what I wanted to know. Figured it wasn't just left open but you never know with Land Rover... The seal covers the gap but the water dripping off the end of the rain gutter runs down the door seal and finds its way through that gap. I'll try silicone and see if that does the trick.
Old November 15th, 2016, 04:25 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Door seal issue
Hi everyone
Sorry to bring this up again but have a similar problem.
But i have it from the top of the door where roof meets winscreen panel.
I have water leaking from the top of the door down.
Any ideas how i can fix this?
I know how to go crazy with silicone but i don't want to do that this time.
Please help
Old November 15th, 2016, 04:56 PM
Is it missing the seal between the windscreen and roof?
I have a seal between my windscreen and roof and have zero leaks (really)
Old November 15th, 2016, 04:57 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
You mean that putty? Butyl black?
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Yup, that's a leak alright. I would say it looks like it all the way across the top of the door.
Could be several things, most of them to do with the door position, and not sealing properly. Possibly the striker position is not holding the door firmly against the seal, or the door seal it's self needs to be replaced.
Check the gap around the door when it's closed, it should be even on the sides and top, not tilted in one direction. It should also be flush to the bulkhead and the rear door. You may want to try moving the striker slightly inboard more, so the door squeezes the seal better. Failing that... try replacing the whole seal.
Old November 15th, 2016, 05:01 PM
chuckc4
chuck b
Registered User
Olsin, if your seals are the original ones, then it might just be time for new seals. Water is insidious‚—even a new seal in a Land Rover can struggle against it...
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Hi.
Thank you for detailed reply and your time.
Actually door seal its new. The striker also and the door is aligned. To me is fine and it touches/pushes the seal all around.
I am suspicious of that roof-windscreen frame meet point which is slightly off lined.
I will take pictures maybe tomorrow morning.
------ Follow up post added November 15th, 2016 10:03 PM ------
All seals are new. This is what makes me scratching my head
Old November 15th, 2016, 05:15 PM
No, it's not putty. It's a neoprene or buna rubber foam closed-cell foam seal, at least 1/4" uncompressed thickness.
I've seen people try to fix this with a tube of silicone, but it's not the right way to do it. If this is a secondhand truck, there's no telling what's sealing the windscreen to the roof.
Old November 15th, 2016, 05:17 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Right, ok will check if any left of that there.
Thank you a lot!
Old November 15th, 2016, 06:11 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Yes, post some pictures.
Was that water down the inside of the door after driving , or after just being parked?
Your door seals, Genuine, or ?? (God, please not Britpart)..
Old November 15th, 2016, 06:33 PM
even britpart door seals wouldnt cause a leak like that. i run britpart door seals left and right and have no leaks.
Old November 15th, 2016, 09:07 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
After being parked but worse wen driving
Old November 15th, 2016, 09:38 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
No, Britpart seals wouldn't cause it specifically, but the fit isn't always consistent. It could be considered to be one of the many variables.
If that is the amount of water leaking in while being parked, (the whole length of the door top), there must be no contact between the seal and door top.
Old November 15th, 2016, 10:14 PM
for sure...I would hope that sort of gap would be obvious to the original poster, however!
Old November 16th, 2016, 01:51 AM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Sorry for the delay because of time zone. Here is 8 am now.
I just checked again. Seal and door have very good contact. I still believe there is water entering from the part where they connect (roof nad winscreen frame)
I will remove seal and check.
When i drive there is more water coming in much more than when parked.
Battery Issue or Charging Issue? icnsltmfg Defender Technical Discussions 4 May 19th, 2016 01:25 PM
Satisfied Badger Fabric Door Seal Users? Auspex Misc. Chit-Chat 10 April 6th, 2007 11:10 AM
rear door seal (bottom) and plate mattdh For Sale - Parts 8 April 2nd, 2006 02:35 PM
Door seal D90user Wanted 1 October 14th, 2005 02:41 PM
Door seal and gutter kit Chris Cox Defender Technical Discussions 11 March 7th, 2004 10:52 PM
