Door seal and gutter kit - Defender Source
Old February 17th, 2004, 09:56 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
What parts are needed for the gutter kit for a ST?
I am placing a big order for parts this week out of the UK, and wanted to order the parts to install the gutter kit. I have a epc, but I don't quite know which parts I do and don't need, as they are normally used with hoops instead of rollcage. If anyone has any pics they could send me tonight or tomorrow, that would be a great help.
Old February 17th, 2004, 10:27 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
from what I can tell by looking at the epc, it looks like I need the top drain channels, part #'s RRC3972/3, and side drain channels, part #'s MTC5428/9, and mounting hardware.
Thanks again for the help.
Old February 17th, 2004, 10:32 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Couple of other questions. Do the gutter kits work as good as everybody says, and can they be used with a besttop, or strictly the bader top?
Old February 18th, 2004, 10:45 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Chris,
The gutter kit works well. It forms a solid frame that will eliviate most the drafts associated with the ST. Just as good as the fiberglass hard top for sealing around the doors.
The Best Top can be made to work. I believe Chris at Badger has done this work. Im not sure your average shop can do the work.
Dont forget to order the weather striping for the gutter kit.
What is the price on the top and side drain channel?
good luck with your search
Old February 18th, 2004, 12:08 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
It looks like it will be about $225 for all the parts- top and side drain channels and all new bolts. It seems like the tops were about $90, and the sides $20. Does this sound reasonable?
Old February 19th, 2004, 09:56 AM
ron's Avatar
ron
Ron
Chris, is the top gutter piece galvenized?
that sounds like a good price. The shipping is what kills u but if u have a bunch of stuff coming in to spread the shipping its not bad.
are you going to order the weather stripping as well or make your own?
Whats the plan once u get the kit convert the best top? Or order a top from Badger
Old February 19th, 2004, 08:22 PM
Krna
Andy Krna
1997 D-90 ST AA Yellow
Does the gutter kit require any permanent modifications? or drilling into the body?
Anyone have pictures of it?
Old February 28th, 2004, 01:19 PM
Krna
Andy Krna
I was wondering if the door seal/gutter kit for the soft-top is a permanent modification. Also, does anyone that has this have any pictures that they can post, both top on and off?
Old March 1st, 2004, 11:44 AM
ron's Avatar
ron
Ron
andrew, the gutter kit is a bolt on unit. there is no sprecial modicfication except maybe the header piece on the windshield. sometimes you have to cut of the ends with the snaps.
other than that it takes about 15 minutes to put on.
I forward some pics .
Old March 1st, 2004, 10:04 PM
Krna
Andy Krna
thanks, i would definately like to see some pics
Old March 7th, 2004, 07:09 PM
Krna
Andy Krna
ron, have you taken those pics yet?
thanks,
andy
Old March 7th, 2004, 10:52 PM
ron's Avatar
ron
Ron
sorry andrew i thought i was buying a 97 SW this week end but the seller neglected to tell me that all 3 doors had rust.
forward your remail address to me and ill forward some pictures.
My gutter kit is a little different than the norm as mine is painted red to match my truck.
door, kit
Gutter Kit Pictures Grover Defender Technical Discussions 8 February 2nd, 2006 03:59 PM
Badger Soft Top with gutter kit Tom B For Sale - Parts 2 December 16th, 2005 05:35 PM
How To install Badger Gutter Kit ??? Help TDI Guy Defender Technical Discussions 4 November 5th, 2005 05:41 PM
Gutter Kit w/ Rovers North (Badger) Top mgrgpg Defender Technical Discussions 4 March 28th, 2005 12:56 AM
Badger Gutter Rail Kit TDI Guy Defender Technical Discussions 3 March 24th, 2004 09:55 PM
