Door poping open - Defender Source
Old November 18th, 2007, 03:13 PM
Big D
Daniel Brown
Door poping open
My passanger side door has been popping open while driving lately. If I dont lock the door, it pops open but when locked it never happens. Could be a great 007 move to get rid of a bad guy but my girlfriend does not find the humour in my ejecting seat. Any ideas. Thanks always for your time and help.
Old November 18th, 2007, 06:59 PM
Daniel, if the door is aligned properly, and otherwise opens and closes smoothly, it sounds like the latch is buggered. What vehicle/year? You can replace the latch assembly easily on a 94/95 - about $70 from RDS iirc. I am not sure how to remove the lock though, so you'll probably need new locks and keys (assuming you ever lock it)
Old November 19th, 2007, 09:50 AM
Big D
Daniel Brown
I have a 95. The door seems to be aligned correctly but I will take a closer look. Thanks for the help
Old November 19th, 2007, 06:39 PM
Just make sure it really was closed properly the times it flew open. On mine, sometimes the catch would hit the striker bar (but not fully pass over it and wrap downward) so the door would seem to be closed until I hit a corner. If this is the case you can adjust the striker assembly downward slightly. Use a 10mm socket to loosen the 2 bolts that hold it, lower it slightly, re-tighten, and check how she closes. I think the door sags as the hinges wear.
hth
charles
Old November 20th, 2007, 12:24 AM
Ray Bone's Avatar
Ray Bone
Ray Bone
defender.
adjust the door striker, it will be fine.
Old November 20th, 2007, 08:47 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
also make sure your body stiffeners are in place. these are the meteal brackets that bolt to the wheel well and the body frame that the strickers bolt to. If they are not there the body will flex and the door will fly open. I almost lost my wife but she was wearing her seat belt ; )
Check the strikes and hinges as well.
door
OPen loop stall, or at least I think it is open loop! Neo Defender Technical Discussions 18 January 25th, 2012 11:34 AM
doors won't open WhiteD90 Defender Technical Discussions 5 November 27th, 2008 01:26 PM
Thermostat Stuck Open? johare Defender Technical Discussions 12 March 16th, 2006 08:58 AM
OT: NASA's JPL Open House - This weekend, May 14-15, 2005 arbik Misc. Chit-Chat 0 May 13th, 2005 06:47 PM
Nevada Trophy Entries are open -- April 29 rally Doug Misc. Chit-Chat 3 January 29th, 2004 08:51 AM
