Door only locks from the inside - Defender Source
Old January 21st, 2016, 12:37 PM
TELOS's Avatar
TELOS
Nate
LHD 110 SW - 300Tdi
I'm having a strange issue with my driver's side door. The door is a 1985 with a roll-up window and lift-up handle. The door can be unlocked from the outside just fine, as well as from the inside by pulling up on the lock. When I lock it from the outside, however, the key turns just like it had locked, but the handle still opens the door. The only way to get the door secured is to use the key in the door to "lock it" from the outside, knowing it isn't actually locked YET, and then push the lock down from the inside. ONLY THEN, is it actually locked and secure.
Has anyone else had this issue? Looking around the door locks and mechanisms, everything appears to be okay but I need to dig deeper and not quite sure where to look.
door
Door locks and tailgate door - 2007 Denver90 Defender Technical Discussions 9 February 27th, 2013 12:22 PM
Where can I find the pads that go on the cage bar inside the SW? Pic inside... KKilo23 Defender Technical Discussions 6 June 26th, 2009 05:36 PM
Inside Door Panel Reinforceing The Wizard Defender Technical Discussions 30 November 15th, 2006 05:03 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 08:31 PM
Inside door storage bags Campbell Wanted 0 March 13th, 2004 10:17 AM
