Door Locks Don't Lock - Defender Source
Old August 26th, 2005, 03:38 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Hi all, the drivers side door lock no longer activates with the key from the outside with the door closed. Began a month or two ago. Then the passenger side door lock is acting funny, sometimes it'll lock with the key, sometimes not. Both will unlock with the key, neither will lock from the outside with the key.
Rear door works fine. Is this a worn out door lock tumbler assembly issue or some weird needs to be cleaned or reset issue?...
Anything is possible, with the right tools...
Old August 26th, 2005, 04:07 PM
Ray Bone's Avatar
Ray Bone
Ray Bone
defender.
order a new barrel, $14.99 from LR dealer.I did that last week.
Old August 27th, 2005, 11:31 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
did you try wd-40 in the key hole? May clean out any debris. I would try that before you start taking the whole lock assembly apart.
Old August 27th, 2005, 04:57 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Well I wouldn't recommend WD40 or any liquid in a keyed assembly. Graphite puffer bottles are the best for lubing keyed locks and such since the dry powdered graphite won't attract grit and such. Will try it, but likely will buy new barrels.
door
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
Tuffy Push Button Keyed Lock for sale mgrgpg For Sale - Parts 1 March 9th, 2004 01:48 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
lock the tailgate?? Campbell Defender Technical Discussions 9 December 8th, 2003 05:46 PM
