Door lock and striker - Defender Source
Old November 30th, 2006, 11:26 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
Anyone ever had any experience replacing the driver and passenger side door lock/hadle and striker? Is it a big job or is it just a matter of replacing old with new?
Thanks for any help
Mike Lynch
Old November 30th, 2006, 11:37 PM
The lift-up type like on the soft top? Super easy. 2 nuts and 2 screws on the door latch, and 2 on the striker. It takes playing to realign the striker when you put it back together, but its easy.
Old December 1st, 2006, 12:08 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
The only thing to consider, which took me a while to realize, is that the striker portion may need to be adjusted outward/inward. I kept trying up, down, up, down, left, right, left, right (B, A... nevermind), but nothing worked... and then I remembered what those thin metal shims were for.
Old December 1st, 2006, 09:32 AM
I will take the old ones if you don't want them and are willing to part with them reasonably.
Ron
evilfij at yahoo dott com
Old December 1st, 2006, 09:47 AM
Monkeyboy
Guest
Posts: n/a
Metal shims!?!? Mine are PLASTIC?! ('97 SW)
And my drivers side door is getting harder and harder to close and latch ... any suggestions for improving the alignment ... aside from improving my IQ ... it looks dead simple, but I'll be darned if I can get the bits lined up well.
KAA
Old December 1st, 2006, 10:23 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Keith - The shims on my 97 are metal with a white plastic coating. Sounds like you just need to move the striker out towards the latch a little. Last time we were out Beth noted more noise than usual coming in. The striker came loose and needed to be moved back in some to close the gap. The doors are a pet peeve for me. The driver/passenger doors are easier, the back door drove me nuts for a little while. HTH. Mark
Old December 1st, 2006, 10:27 AM
Monkeyboy
Guest
Posts: n/a
Really! Thought they felt like plastic ?
I'll loosen the attachment and keep them in line with a square then move "outboard" a touch and retighten.
"Hi" to Beth and Marshall too
Old December 1st, 2006, 10:42 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Ron
It is easy to do. I did mine the other weekend. I replaced the locks and handles. the one hting you need to look out for, which everyone has said is the striker position. i had to more my strikers out about 2-3mm each so that when i shut the door the latch would click down to its resting position so that i could use the door locks and lock my shit up!
if the striker is too far in you will be slamming the door very, VERY hard to make sure that third click on the latch happends... well this is if you want to lock your truck up too
-Ron, i have a Left and Right one if you want them. the locks are stuck in them, but im sure you can get them out if you try a little bit hard than i did. haha.
Old December 1st, 2006, 11:12 AM
Defender13's Avatar
Defender13
Mike Lynch
would these latches work for a 1994 ST
Door latches
Mike Lynch
Old December 1st, 2006, 11:35 AM
ini88's Avatar
ini88
Daniel Marcello
looks like the same ones i bought. they should work. 99.99% sure those are the ones
Old December 1st, 2006, 11:45 AM
Cool dan,
I will shoot you an email. I need the strikers too.
Ron
Old December 1st, 2006, 12:28 PM
Defender13's Avatar
Defender13
Mike Lynch
Daniel,
where did you buy yours?
Mike Lynch
Old December 1st, 2006, 12:34 PM
ini88's Avatar
ini88
Daniel Marcello
I got mine from Atlantic British
Item: 6324
Item: 6325
it says Series 3 but they are the same on the Defenders too
http://www.roverparts.com/ProductLis...or&PartNumber=
they have right and left and strikers too.
Ron send me an email. I dont have the strikers, but you can find those for cheap
Old December 1st, 2006, 12:46 PM
themaxx's Avatar
themaxx
Ade
94 ST
Thanks for any help
Hey Mike,
Take a look at this post, ECR gives some good info about replacing the striker: http://www.defendersource.com/forum/...hlight=striker
Old December 1st, 2006, 01:30 PM
If anyone has a couple strikers that would be great. I can send a few bucks and pay for shipping.
evilfij at yahoo dot com
Old December 1st, 2006, 04:05 PM
Keep in mind that new striker also have to be adjusted. There are two screws on holding the rubber buffer on, these sometimes need to be screwed down to compress the buffer - the the bottoms of the screws have to be filed off. When I installed Janey's front ones, the right side went on perfectly as supplied, but the left door required the buffer to be compressed almost by half.
Old July 23rd, 2017, 08:52 PM
meow
Johnny
'87 90
oops wrong thread
door
SW door striker mightymg Wanted 2 October 25th, 2009 06:27 PM
Door Striker Shims fleabus Wanted 0 October 12th, 2009 11:06 PM
1/Genuine Striker Anti-Burst - $25.00 NashvilleRover For Sale - Parts 1 September 22nd, 2009 01:20 AM
Bonnet/Hood Striker Plate pcscharfe For Sale - Parts 2 August 19th, 2009 09:52 PM
Need measurement for NAS rear swingout striker dave_lucas Defender Technical Discussions 2 June 5th, 2009 04:25 PM
