Door Lock - Defender Source
Old September 22nd, 2008, 12:25 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
Door Lock
My driver's side door lock appears to be loose. When I turn the key from the outside it is loose and the balck lock tab on the inside only moves up half way. Sometimes it locks other times it does not. Before I take this apart is this something that can be fixed or do I need a new lock?? It appears that to take it office I will need to remove the plastic door liner and there some bolts holding the lock thingy onto the door??
Old September 29th, 2008, 02:43 PM
Craigd's Avatar
Craigd
Craig Dickson
Okay so last weekend I took the door apart and it appears that the door lock and handle is a one piece unit. I found that you can buy replacements at AB, only they don't come with a lock. So my question now is, how do you ge the lock tumbler out of the old and put into the new?
Old September 29th, 2008, 11:08 PM
surf110's Avatar
surf110
Ze
130 Project
No need to buy a new handle.
Lock comes apart if you remove screw from this piece. See photo.
The keys come with an aluminum plaque with a key code.
Or buy a new lock and take it to a locksmith. They'll match it to your key.
Old September 29th, 2008, 11:59 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
YOu can just take the tumbler out very easily if you change the handle as well.... the pic above is a SW door. Do you have a ST?
Legend in My Own Mind.
Old September 30th, 2008, 12:38 AM
Craigd's Avatar
Craigd
Craig Dickson
Mine is a ST. It looks like the lock core should come out somehow..
Old September 30th, 2008, 12:40 AM
You put a key in the lock, and stick a paperclip or something else small down the tiny hole in the face. This releases a tiny little button at the back of the cylinder and releases it.
Old September 30th, 2008, 06:31 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
the hole is actually on the side of the barrel I believe
Old September 30th, 2008, 07:06 AM
Oh, right!
Old September 30th, 2008, 01:43 PM
Craigd's Avatar
Craigd
Craig Dickson
I saw that hole. I will try that and see what happens. THanks!!
Old September 30th, 2008, 02:17 PM
You just have to poke around in there to get it to release - not always super-easy for the same reason that locks get stiff - crap stuck in there.
Old September 30th, 2008, 11:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would WD-40 The Shiznit out of it... I did it once..
Old October 1st, 2008, 01:56 PM
Craigd's Avatar
Craigd
Craig Dickson
When I took the door apart I squirted PB blaster all over the lock components to clean the mechanisim hoping that would help with the functioning of the lock. Hopefully that will loosen stuff up while I am in Vermont hunting. The lock will have to wait until I get back...
Old October 1st, 2008, 03:05 PM
specops1526's Avatar
specops1526
Beluga '97 90
My lock malfunctioned once and the dealer said they had to replace the whole part because it was a sealed part...anyway, they replaced it and had it rekeyed. This was when I had the hardtop on. I guess since taking it off I've never used the locks again...best solution to never having them break again!
With a soft top I figure it's useless to even use the locks, it just invites people to cut thru the top...Good luck with the fix though!
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
door
