Door Leaks - Defender Source
Old December 7th, 2009, 05:59 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Door Leaks
Its raining here in southern california and now I am having some leaking issues. I am getting water coming in the top of the driver and passenger doors. It comes in between the rubber seal on the door jam and the rubber strip attached to the door. I turn corners and get streams of water going down the windows and on to the door panels on both driver and passenger sides. Rubbber appears to be fine and doors fit well so I'm not sure how to fix it.
Anyone else deal with this leak before?
Old December 7th, 2009, 06:32 PM
Cory's Avatar
Cory
Shane
D90SW 1997
Only when it rains . . . and here in VA, that's been everyday for the past few weeks. http://www.defendersource.com/forum/...cons/icon6.gif
There's a few solutions for it:
Option 1. Remove carpet, wear rain coat while driving.
Option 2. Sell Defender, buy anything else.
Option 3. Do everything in this ingress manual: http://land-rover.team.net/manuals/WaterIngressManual.pdf
More than likely, you'll need to check out the page "'A' post leak."
Old December 7th, 2009, 07:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
I had the same leak on my drivers door. It was the seal under the rubber strip in the upper corner. I removed the rubber door seal, then removed the crappy seam sealer in corner and redid with dum dum strips and black duct tape so it looks the same. no leak today in Socal for me.
Old December 7th, 2009, 07:09 PM
hotroddef90's Avatar
hotroddef90
Rod Renfrow
1995 Defender 90 ST
I replaced all weather stripping on both doors but still leaks! I can't even drive mine right now cuz everything is so wet! It's messing with the electical of the d90 and I'm gonna get a car cover for it to keep it dry.. I need to look into that dumdum seal!
Goodluck!
Old December 7th, 2009, 07:15 PM
#1 for me. The snow coming in at speed through the gap the soft top leaves at the corner of the windshield can be irritating too, but a glove stuffed in there keeps it out just fine. Flip flops avoid any issues getting shoes wet.
Old December 7th, 2009, 07:21 PM
LOL.Everyone has. Welcome to land rovers. In socal guess its a bit less annoying
Old December 7th, 2009, 08:13 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Cory, thanks for posting that manual, very cool.
I guess I am starting to learn all the nuances of Defender ownership.
Mine is the Door seal at the corner like Barry had (Process 2.5 in the manual).
Where can I get the dum dum strips?
Old December 7th, 2009, 10:23 PM
hotroddef90
Rod Renfrow
1995 Defender 90 ST
Dum dum strip
I want dum dum strips too, where do I get some?
Old December 7th, 2009, 10:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
It is 3m strip caulk. do a google search
Old December 7th, 2009, 10:37 PM
For my first 5 years of land rover ownership, I did not run any top 90% of the time, even in winter.
Old December 8th, 2009, 01:48 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
You forgot "drill a hole in the floor to allow the water to drain out."
Keith
Big, Red and ... aaa Red..
Old January 2nd, 2010, 04:14 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I recently ordered new door rubber seals for the bottom doors (Part: MWC6130, see attached pic) and I noticed that they are different than the ones currently installed. I have thinner 3M seals and these new ones have a lip with holes in it. It appears that they are supposed to be riveted into the doors but the holes don't match up with the holes on the door bottoms. I looks in the NAS parts manual and this is the part specified there. I suppose I can just cut new holes in the door seal? What does your bottom door seal look like?
Old January 2nd, 2010, 08:41 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
I usually keep the rubber mats pulled out of the car - water on the bar metal floor dries much quicker.
I have often wondered about building some 1/4" dam out of something about 3" in from the door jamb on the floor. It seems like if I could just keep the water at the edge of the floor - it would drain out. The door jambs leak as much out of the truck as the window tops do into the truck..........
It might mean that the whole floor does not get wet - just the outer edge?
Anyone done that?
Flagg
Old January 3rd, 2010, 02:43 AM
i ended up doing this.
1) Buy SW doors (roll up windows) from safari rover. paint, etc (huge improvement here, and the roll up window makes a massive difference in general comfort)
2) bought a badger II top with the Gutter kit 3)
3) did everything in the water ingress manual for the pillars, and foot box.
door and most other leaks are gone its not 100% dry but call it 95%. it did pretty good this week in the mountians with 2 people in the back it was livable (20"+ inches of snow and then rain in the lowlands where we live)
Spendy though (figure 2K for the doors, and 3K for the top)
- the stock best top does not seal very well - you can pick up some gains by realigning the top (try it several ways L/R and see if that helps)
95' D90 - daily driver..
Old January 4th, 2010, 11:55 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have SW (roll up window) doors. Is the door bottom rubber seal supposed to be pop riveted into those? That's what the parts manual says, just curious what other NAS SW D90 owners have on the bottom of their doors.
door
