Door Latch Removal - Defender Source
Old July 23rd, 2006, 10:55 PM
outfield
Steve
1995 D-90 SW #351
Door Latch Removal
The door latch on my 95 SW will not stay latched any longer. It looks like the window track needs to be removed to take the door latch off. To do this the window needs to be removed. Well, i have not had any luck removing the window or the window tracks. Has anyone out there done this that can help?
Old July 24th, 2006, 08:41 AM
cpk
Corey K-nig
1993 NAS Defender 110
Before you go through all that trouble try spraying WD-40 or PB Blaster into the latch mechanism from the outside and inside if you have the inner door panel off. After that work the outside and inner handle to see if it loosens and works. Because all the elements of the mechanism are exposed to dirt and corrosion it may be stuck in the open position.I just dismantled a door that was stuck closed because of this. I thought it was broke, but that's all I had to do.
Old July 24th, 2006, 02:49 PM
outfield
Steve
1995 D-90 SW #351
Thanks for the advice Corey. When the door is open I can push the latch to the latched position with a scew driver, but then I can easily unlatch is also with the screw driver. I'm thinking a pin or lever may have broken inside.
Old July 24th, 2006, 05:22 PM
o its easy to take off. most of the plastic bits pop out. the window winder has sort of a cir clip thats a pain in the ass. theres a thread that might be of some help ill try and find it
http://www.defendersource.com/forum/...ght=door+panel maybe that willbe of some help..
Old July 24th, 2006, 11:49 PM
outfield
Steve
1995 D-90 SW #351
Actually I'm having trouble removing the latch mechanism that connects to the striker located on the door jam. The latch is inside the door and held in place with 3 screws. I removed the screws but can't snake the latch out.
When my door is closed the latch is no longer holding the door in place, you can just pull the door open.
I got it, and only bent one small part while doing it. Thanks for the help again guys.
door, door latch
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Fender removal flippedrover Defender Technical Discussions 3 April 9th, 2004 09:56 AM
