Door latch - not latching - Defender Source
Old September 23rd, 2016, 06:38 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
On my 110 station wagon the left middle door has been difficult to lock. You push down on the interior button, it just didn't want to 'click' into locked.
So, I adjusted the latch position (in the door frame) but that didn't help. Then I loosened the hinges and adjusted the door position a little. Now I can lock it but the door isn't latched. You lock the door, tug on the handle and the door opens.
Yes, it will open while driving.
Any quick tips for CORRECTLY adjusting doors & latches?
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old September 23rd, 2016, 07:00 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
I had the same problems with mine. I had to replace my door mechanism. This thread may help you: http://www.defendersource.com/forum/...ent-37845.html
The metal catch had worn enough that it didn't hold the latch anymore. I realized this when I compared it to the other door mechanisms and noticed the shape of the metal was different. Good luck.
Old September 23rd, 2016, 10:39 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
I'll read the other thread.
This door mechanism is only 2 months old. Maybe I need a warranty exchange.
Mike & Carrie
Old September 24th, 2016, 01:22 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Sometimes the answer is right in front of you. In other words, it's obvious if you just look. And think.
Looking at the pin (bracket) on the frame, I finally noticed the strike pattern is at the extreme farthest out point on the pin. "Hmmm, maybe the latch is blocked by the bracket?"
So I put in two washers, moving the bracket out from the frame. Now it closes securely and easily. And it locks easily.
VICTORY!
Yes, I know, the "correct" solution is probably to leave the bracket where it was and adjust the door closer to the bracket.
But, as a VERY wise Camel Trophy owner once said "Better is the enemy of good!"
Mike & Carrie
door, door latch
door latch mechanism reassembly peachyracer Defender Technical Discussions 0 July 22nd, 2010 06:08 PM
D90 Station wagon Door Pannel/Latch parts arbik Defender Technical Discussions 2 January 16th, 2009 06:50 PM
Door Latch/Top Adjustments AggieD90 Defender Technical Discussions 6 November 19th, 2008 03:55 PM
SW rear door latch mechanism roverboy For Sale - Parts 8 March 22nd, 2007 02:42 PM
Door Latch Removal outfield Defender Technical Discussions 4 July 24th, 2006 11:49 PM
