Door latch adjustment / replacement? - Defender Source
Old May 29th, 2012, 11:21 PM
motap
neal
My drivers door handle / latch is very loose. There is no resistance when you lift up on it from the outside to open the door especially when comparing to the passenger side.
Is this something that I can adjust from the inside by removing the door panel or is it time to replace?
Thanks in advance,
Neal
Old May 30th, 2012, 05:17 AM
maleger
Marc-Andre Leger
What vehicle ? What Year ? What kind of door handle ?
This would help to answer your question.
Old May 30th, 2012, 09:18 AM
motap
neal
Sorry -- NAS 95 D90 ST
Old May 31st, 2012, 09:48 AM
motap
neal
bump
Old May 31st, 2012, 10:35 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Don't know if its the same problem, but my passenger side handle had the same symptoms when I purchased the truck. I sprayed lube in every orifice around the lock and latch. It freed it up. It was stuck in the open postion and wouldn't latch closed.
Old May 31st, 2012, 10:50 AM
I think you can also move the door striker pin that is on the truck bed, to the outside a tiny bit to help with this.
Old May 31st, 2012, 12:54 PM
motap
neal
Great -- I have a wurth lubricant that generally works well.
I will try it -- but it's not so much that there are problems opening closing the door as there just isn't enough resistance in the handle.
Will report back.
Old April 3rd, 2016, 01:52 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Sorry to bring up an old thread but I could not find anything from searching. Anyone have instructions on how to install a new latch mechanism for a 93 110 SW? It looks like the mechanism is between metal pieces without a way of getting it out?
------ Follow up post added April 3rd, 2016 12:59 AM ------
Old April 5th, 2016, 03:01 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Thank you all for not answering my question and forcing me to dig deeper into the manual. Found my answer. Ha ha! I'll post this for any other lazy bum just looking for the quick answer.
Name:	Screen Shot 2016-04-05 at 1.55.04 PM.jpg
ID:	146663   Click image for larger version
Name:	Screen Shot 2016-04-05 at 1.59.52 PM.png
Name:	Screen Shot 2016-04-05 at 3.50.46 PM.jpg
ac, door, door latch
Steering box replacement & adjustment 16kpsi Defender Technical Discussions 1 January 17th, 2011 06:38 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 11:24 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
