Door Hinge Screw Stuck - Defender Source
Old October 17th, 2012, 06:09 PM
Hinckley423's Avatar
Hinckley423
Charles Joerss
1995 D-90 #2812
So I went to replace the screws on my D90 ST that hold the door hinges to the body of the truck and I was able to get one screw out but when I went to put the new one in it wouldn't go. I finally got the old one back in but now it keeps spinning and I can't get it out. Any ideas?
I appreciate the help.
Old October 17th, 2012, 06:13 PM
The clip that holds them in broke. Basically you have to drill out the heads and replace everything. Reinstall with anti-seize over everything.
Old October 17th, 2012, 06:28 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Ron, will i run into this issue if i am using my same hinges from my S3, to mount my Defender SW doors too? Im not removing the hinges from the Bulkhead.
Old October 17th, 2012, 07:06 PM
No John, you will be fine. It is only the bulkhead side screws (and b-pillar on 109/110) that have the issue. The door side have normal nuts on the other side.
Old October 17th, 2012, 07:09 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Here's a pic if you've never removed one, bottom 2 pics. The clips are only on the bulkhead side:
http://www.defendersource.com/forum/...7&postcount=83
MUDSUX
Old October 17th, 2012, 07:57 PM
Hinckley423
Charles Joerss
1995 D-90 #2812
This might be a loaded question but how difficult is this to fix?
Old October 17th, 2012, 08:44 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Sharp drill bit, no problem
Land Rover 110
Old October 19th, 2012, 03:14 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hey Charles, in case you want to go stainless, I just did this write up in my rebuild thread:
SS door hinge bolt upgrade
MUDSUX
Old October 22nd, 2012, 03:04 AM
JackDEF90's Avatar
JackDEF90
Jack Nicholls
2002 Defender 90 station wag 2.5 D
That issue is on this months land rover monthly. Go buy it will give you a run down in the technical section when replacing a front door.
Cheers
door
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
Stuck In Iraq javelinadave Misc. Chit-Chat 5 April 12th, 2004 07:53 PM
