Door hinge screw replacements - guidance - Defender Source
Old September 20th, 2004, 05:09 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
I need to replace my door hinge screws. I pulled the below off E-bay. Does anyone know if these fit a 1994 NAS D-90? Are the US Defender screw metric or not ? This is to confusing for simple minded folk like me. Just want to drive and rust away...
FROM E-BAY
Land Rover Defender 90 replacement Stainless Screws
Bonnet
Driver / Passenger Door
Rear Door
Offered here is a kit consisting of all metric stainless fasteners required to replace rusted torx-headed hinge screws on your Landy (1998 on-).
Please note that this item will fit pre-1998 and Series Land Rovers provided that the door post J-Nuts are replaced with metric J-Nuts, also available in my Ebay Shop . You will require 8 J-nuts, and 4 captive double nut plates, although the latter can be omitted and replaced with the supplied nyloc nuts.
All fasteners here are hex socket which require an allen key to tighten. Rear door screws - choice of Socket Button or Pozi Pan (as per originals) heads, please specify after auction ends.
Stainless nyloc nuts are supplied for additional security, and washers.
UK P+P is £2.50 , overseas £7.00
Considerable effort has been made to ensure that the fasteners are of the correct head diameter to fit the recesses of the hinges. You cannot buy these items off the shelf, as they won't fit!
Original Land Rover J-nuts and 2x captive nut plates also available in my Ebay Shop as well as Rear Door Pozi Screws and LR110 hinge screw kits.
Old September 21st, 2004, 10:59 AM
Scroll down about 3/4 of the way, there is a bolt substitution table.
http://www.defendersource.com/tech/part_sub.html
Old September 21st, 2004, 12:45 PM
paulb's Avatar
paulb
Paul / Boultbee
just what I needed.
And I will not ask why the bulk vs driver door screws are 1.5' vs 2.5"
Old September 21st, 2004, 08:39 PM
DON'T!!!!
Just put some paint and then clear grease on the heads. It is a PITA job.
Ron
Old September 22nd, 2004, 06:51 AM
Kev Baldwin
Kevin Baldwin
2.4 Tdci 110 Utilty Wagon
You will definitely need to replace the 'J-Nuts or captive 'Cage Nuts' in the bulkhead door pillar for metric replacements. Chances are when you attempt to remove the bolts from the door pillar they'll refuse to budge, meaning you'll end up drilling the heads off athe bolts anyway. Bottom bolts that attract all the crap tend to be the worst. With the bolts siezed in the cage nuts, you'll need new cage nuts anyhow. Reason kits are metric is you cannot get hold of the correct 'imperial' cage nuts anymore.
An alternative SS bolt kit at: http://www.mudstuff.co.uk/Stainless_...Bolt_Sets.html
ac, door
OEM Antenna or Replacements boshea Defender Technical Discussions 14 January 18th, 2006 01:15 PM
Need fuse box thumb screw evilfij Wanted 1 June 20th, 2005 10:24 AM
97 defender st - headlight retaining screw Rob Defender Technical Discussions 1 April 25th, 2005 06:22 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
