door hinge question - Defender Source
Old October 27th, 2014, 06:17 PM
9492
Shawn
1994 Defender 90
door hinge question
My passenger door is difficult to open and close. This weekend I decided to adjust it. I noticed that the door hinges are tapered. The top hinges on both the driver's and passenger's doors are wider at the bottom and narrower at the top. The lower driver's door hinge is also wider at the bottom and narrower at the top. The lower passenger door hinge is the opposite of the others. It is narrower at the bottom and wider at the top of the hinge. Has this hinge been replace with the wrong hinge?
Old October 27th, 2014, 06:27 PM
9492
Shawn
1994 Defender 90
Thanks for the quick reply. I think the wrong hinge is contributing to the difficulty opening and closing the door.
door
Door hinge question Nate6472/ Defender Technical Discussions 5 October 7th, 2013 01:18 PM
Lift gate upper hinge bracket pictures / question dave_lucas Defender Technical Discussions 7 May 21st, 2009 12:07 AM
Door hinge pin mspell Defender Technical Discussions 1 September 8th, 2004 04:14 PM
Rear Door Hinge Replacement Rob Defender Technical Discussions 2 January 21st, 2004 01:26 PM
Rear Door Hinge Screws Rob Defender Technical Discussions 1 October 12th, 2003 06:46 AM
» Defender Registry
90
clb1994
Defender90
Sam401
Add your Defender
