Door hinge question - Defender Source
Old October 7th, 2013, 12:48 PM
Nate6472/
Nate
88 D90 V8
Door hinge question
I have hinge missing a screw and fastened by a bolt. There is nothing in the missing screw hole to screw into. Door sags a bit. What is the solution to this? Cheers
Old October 7th, 2013, 01:01 PM
j-clip assuming you are talking about where the front door bolts to the bulkhead
Old October 7th, 2013, 01:05 PM
Nate6472/
Nate
88 D90 V8
Correct, the female portion in the bulkhead. J-clip? Is that the land rover term or general hardware term?
Old October 7th, 2013, 01:07 PM
it's a standard term
Old October 7th, 2013, 01:09 PM
aka "Clip On Nut"
The shape you want is a "J-style Clip-On Nut".
Old October 7th, 2013, 01:18 PM
Nate6472/
Nate
88 D90 V8
Ok, I know what u mean. I have never seen the bulkhead side without a hinge mounded. I was reluctant to unscrew the bolt not knowing how it was fastened - "rigged"
door
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
