Door Hinge Nut - Defender Source
Old January 4th, 2005, 09:48 AM
Jeff 95/126
Jeff Grill
1995 D90 126/500
Door Hinge Nut
I have repalced 3 of the 4 D90 hinges (1995) w/ very nice aluminum ones from Motosport.
The problem: The bottom bolt (passenger side bottom hinge) is frozen and I think I have broken the threaded back/bolt from the frame. The bolt moves freely, about 20 dgrees. I used an impact driver and it slipped from loosen to tighten. Any ideas on how to get the screw out and then how to secure or install a threaded nut to repace the original?
Jeff
Old January 4th, 2005, 10:40 AM
jstrong98's Avatar
jstrong98
Jon Strong
If it is broke, you have a few options.
You can drill out the old bolt. Start with a small bit in the center, then work your way up with larger diameter bits until almost all of the bolt is gone, then you can tap the hole using the proper size tap dia and thread/in.
Could also try an "ez-out" designed to bite into whats left of the bolt and break it loose.
Get a can of PB blaster pentrating lube and soak it good, let is set a few hours and try to get it loose with a wrench, I'd stay away from the impact gun, get a 1/2 drive socket wrench and try to break it loose with the extra leverage.
JS
Old January 14th, 2005, 11:05 AM
Peter's Avatar
Peter
Peter
1997 D90
I used the information on this page with success: http://www.landroverclub.net/Club/HTML/hinges.htm
door
OME Steering Damper Nut Sergeant_V Defender Technical Discussions 2 September 10th, 2006 04:16 PM
lug nut cgalpin Wanted 2 July 7th, 2005 10:05 AM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 08:31 PM
Bolt & nut size? Berty Defender Technical Discussions 7 June 3rd, 2004 06:26 AM
