Door handle question - Defender Source
Old July 17th, 2014, 12:34 PM
koltonstanley's Avatar
koltonstanley
Kolton Stanley
defender 130 hi cap
Hi guys.
I have the newer push button handle doors and one handle is coming loose.
Can anyone tell me how the handle is held on and how to fix it......
Do I have to remove the door card to get at it?
Is glue out of the question?
ID:	98889   Click image for larger version
Old July 17th, 2014, 12:47 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Take it to a body shop and pull the card and have the screw tightened. You might want to go to a rover dealership and get some new tees. PM me for further info.
Old July 17th, 2014, 02:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
You have to remove door inside panel, put a drop of locktite on screw before tightening.
Cheers
- Charles Eames
Old July 17th, 2014, 03:01 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The widow crank is the hardest part to remove. It's held it by a horse shoe clip of wire. Use a screw driver to spread the crank away from trim ring & look in there, you'll see it. There is a special tool to push it off but you can "hook it" with something and pull it off too. You'll probably break a perimeter plastic pin or two due to the weak design of the pin.
Look at my post here to see where these "pins" are around the perimeter (white spots/recepticles)
http://www.defendersource.com/forum/...ad.php?t=54956
Old July 17th, 2014, 03:06 PM
tjfslaughter
thomas
Burbon
You have to remove the door lock plunger surround (slides up), the inner door handle (two screws), and the latch release surround (1 screw). It is about a 10 minute job to remove.
Old July 17th, 2014, 03:15 PM
tjfslaughter
thomas
Burbon
see attached
Old July 17th, 2014, 03:43 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
Originally Posted by tjfslaughter View Post
see attached
thats perfect guys!!!!
thank you so much!
Old July 18th, 2014, 07:24 AM
Lemonhead
TB
1997 D90 SW
Buy these.
You can get them as cheap as $4 each. One is a Door Panel Removal Tool the other a Window Crank Removal Tool.
You can get away without the crank one but I highly recommend the other - it will make it much easier and help avoid any potential breakage of the panel.
Old July 18th, 2014, 11:26 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I was a locksmith for 20 years and had the bothersome task of being inside many door panels to remove locks. GM's are absolutely the worst, you could always count on getting your arm/hand cut-up on their sharp sheet metal edges. (end of rant)
Anyway, the silver tool is the only tool I used. The small end of the tool is VERY effective at being slid between the panel & then pry sideways to pop off the panel from the little clips or barbed studs that hold the panel to the door metal.
Old July 18th, 2014, 12:21 PM
jputnins's Avatar
jputnins
John Putnins
1995 Defender 90 SW
I've always liked chewing gum for reattaching door handles. As I recall, Hubba Bubba works the best, but others might have different opinions.
In reality, these guys are right on. Removing the door card is easy and then you just need to replace the screw holding that end of the handle on. Some threadlock on the screw would be a good idea for reassembly.
__________________________________________________ ______________
95 D90 ST
Bitsa D110 CSW
Disco 1 "Truck-in-a-box"
Old July 18th, 2014, 12:43 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
converted to jpg
-Jeff
Strange that the drawings/instructions don't show how to remove the window crank handle, the hardest part.
Old July 18th, 2014, 01:29 PM
tjfslaughter
thomas
Burbon
Maybe the tech pub is assuming power windows....
Old July 18th, 2014, 01:53 PM
tjfslaughter
thomas
Burbon
very smart grasshopper
Defender bonnett, SW rear door, and drivers door handle Brewie212 Wanted 4 March 11th, 2013 10:24 PM
Door Handle Pocket - RUST Flagg Defender Technical Discussions 17 November 28th, 2008 04:55 PM
97 door handle retaining screw artm Defender Technical Discussions 0 July 2nd, 2007 11:29 AM
Rust in the door handle??? danb.taylor Misc. Chit-Chat 2 December 27th, 2006 07:02 AM
Interior Door Handle m.michaels Defender Technical Discussions 3 June 1st, 2005 02:52 PM
