Door Draft. Brrrr... - Defender Source
Old December 10th, 2003, 09:56 PM
cdnpaul
Paul
Anyone come up with a good solution to reduce the draft coming in from the side of the doors and the soft top? I know Land Rover had a door seal kit. Has anyone used it? Is it worthwhile?
I tried pipe insulation which someone had suggested somewhere and that helped a little bit but there needs to be some support there.
Old December 10th, 2003, 10:05 PM
JRowe
Jared Rowe
1994 D90. Stock.
i think the only real solution is to trade in the D90 for something w/ real doors and windows.
Old December 11th, 2003, 09:20 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Buy a Station Wagon
Old December 11th, 2003, 01:16 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Go look at the old links. Yousef has a nice add on he made and has posted pics. There is a LR fix - a bar that you can install but I have never found one.
Also, car wash rags ($5 a bag) cut to fit stuffing in gaps, died to the color of your top, dipped in cement sealer and of course stuffed in. Oh, and do a bunch. They fall out all the time.
Next Best solution - buy exmoorland heated seats, North face Glacier pants and parka and take the top off (keep Surrey top on).
And why on gods green earth would you buy a hard top?
(just kidding).
I'm contemplating thinking about thinking about it!
Old December 12th, 2003, 04:03 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Thick coat & hat works for me!
Mike Hammond
Old December 12th, 2003, 04:34 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Thick coat, hat, AND gloves!
Old December 13th, 2003, 01:45 AM
what top do you have?
If you have a tickford there is a kit for like $15 to stiffen the top along where a B pillar would be. Also you want seals in front all the way to the top and in the back where the door meets the tub. A door seal kit would work but you have to cut it as the door seals I have seen are meant for the fibreglass top.
This will get it about as air tight as it is going to get. Made a HUGE difference on mine, then I got a hardtop so . . .
Ron
Old December 14th, 2003, 07:10 PM
cdnpaul
Paul
Ron,
Any idea where I could get that tickford kit?
BTW, Art's drop curtain made a huge difference!
Paul
Old December 14th, 2003, 10:37 PM
Its in the kit book. Any dealer or roversnorth.
Ron
door
