Door Check Popping? - Defender Source
Old November 9th, 2009, 02:27 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Door Check Popping?
Can anyone tell me if their front door check strap has any play in the roller? Meaning if does the roller slide up and down on its mounting pin? I have an annoying popping situation here and I need to make sure these parts arent worn out.
Old November 9th, 2009, 10:16 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I would like to know this too...... I have one door that does this and one that doesnt.
Old November 10th, 2009, 08:23 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
I have the same thing. I'd have to see about the excess play but when I open the door and i push to the outermost limit I get a loud click, or pop as you describe it. BOTH of my doors do the same thing.
This is where I'm supposed to write something witty and funny; or something.
Old November 10th, 2009, 12:16 PM
crown14's Avatar
crown14
Verticalscrote
All that you have to do is pull the door check cover trim (1 screw?) then pull the pin where it connects to the door and slide it out towards the middle of the truck. Should take 5 minutes tops.
Old December 16th, 2009, 09:34 PM
crown14's Avatar
crown14
Verticalscrote
OK can everyone please tell us if your doors pop?
Old December 16th, 2009, 10:19 PM
Grover's Avatar
Grover
Both my doors pop when opening and closing. The roller bearing on the door check arm wears out, becomes loose. The lever/spring (in pic) slams the bearing resulting on the pop.
Old December 16th, 2009, 10:40 PM
crown14's Avatar
crown14
Verticalscrote
Yeah thats what I thought too. Bought two new check straps and guess what? They pop too. In fact the new ones had more play in the roller than the old ones. I went through my notes from before taking the truck apart and both doors popped then too. The more I look at it- it seems due to the design it is going to pop no matter what.
Old December 17th, 2009, 12:19 AM
bjp
Brent
1995 D90
Cheap ?, can you purchase the little z bar in the above pic separately? Mine wore down where the roller crosses it and will not hold the door open anymore. I have seen the kit before but I just need the little bar. Right hand side if anyone has one. They are handed.
Old December 17th, 2009, 10:25 AM
crown14's Avatar
crown14
Verticalscrote
TORSION BAR, LH (FROM HA906553) ALR2319
TORSION BAR, RH ALR2318
rovers north has them less than $2.50 each
I noticed the slightest amount of wear on those, maybe that wear pattern is what is forcing the roller bearing downward, causing the POP
Perhaps I will get a Youtube video up to illustrate this. I wonder if ECR has some magic solution as well.
Old December 17th, 2009, 10:56 AM
bjp
Brent
1995 D90
Thx for the info.
Old December 17th, 2009, 11:34 PM
crown14's Avatar
crown14
Verticalscrote
BTTT once more
Old December 19th, 2009, 02:22 PM
crown14's Avatar
crown14
Verticalscrote
OK does anyones doors NOT pop?
Old December 19th, 2009, 04:42 PM
crown14's Avatar
crown14
Verticalscrote
y'all gonna make me start a poll thread
Old December 19th, 2009, 05:00 PM
Grover's Avatar
Grover
Every D I've ever seen/driven has this problem. It's a poor design that only gets worse as the mechanism wears...
door
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
Clutch pedal sticks to floor, then starts popping up as the truck gets warmer. Quimbola Defender Technical Discussions 7 December 30th, 2008 04:43 PM
T-case popping out of gear Buckon37s Defender Technical Discussions 2 October 2nd, 2007 10:41 AM
Hard Brake Popping Jon_Winningham Defender Technical Discussions 8 December 22nd, 2006 12:15 PM
Power loss and popping! TwisteD90 Defender Technical Discussions 40 May 30th, 2004 12:45 PM
