Door Check hardware - Defender Source
Old July 27th, 2015, 07:34 PM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
Door Check hardware
Hi There,
After having the bulkhead galvanized as part of restoration I'm still chasing thread sizes for various assemblies so that I can re-tap threads before trying to assemble parts.
Does anyone happen to know the thread size of the nut inserts in the bulkhead that the door check bolts into? Basically, I need the bolt size that fastens the door check (door stop) to the bulkhead.
I attached a drawing of the assembly to this post (thanks microcat), but cant tell if it actually attached or not. Anyway, if it did, I need to know the thread size of item 12 in the door check assembly.
Regards,
Mark
Old July 27th, 2015, 11:44 PM
I don't see an attachment, but if we're talking about attaching the bracket to the bulkhead, the inserts are M6. Sometimes you have to chase out extra galv with a drill before tapping, but I guess you've found that out already...
Old July 28th, 2015, 07:12 AM
Mark McDonough
Mark McDonough
Door check hardware
Hi Jim,
Thanks for the reply. Yes, we're talking about the bracket that bolts to the bulkhead that holds the door check arm. My guess was M6 for the fastner bolts.
Do you happen to know thread pitch size for this M6 bolt? Just want to be sure before I go tapping the holes.
Thanks, Mark
Old July 28th, 2015, 08:38 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Should be M6 x 1.0
-Ash
Geared Restoration Co.
352-572-3236
Old July 28th, 2015, 11:27 AM
Which is the "normal" thread pitch for the M6 fasteners found all over the Rover.
Old July 28th, 2015, 10:38 PM
Mark McDonough
Mark McDonough
Door Check hardware
Thanks Jim and Ash.
Confirming here for anyone else that the welded nuts in the bulkhead for the door check hardware are indeed M6 1.0 pitch.
Great resource D 90 Source is!
Regards, Mark
door
what is the best way to remove the hardware on a door to change out the door cards grbec22 Defender Technical Discussions 2 July 28th, 2010 11:21 AM
Misc ROW Softtop hardware / Tailgate Hardware SafariHP The Vendors Loft 0 February 19th, 2009 09:45 AM
••••Fiberglass Hard Top with all hardware and door seals••••• JAD For Sale - Parts 12 February 26th, 2007 08:05 AM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
alt. bracket, door top hardware Abrooks Wanted 0 November 20th, 2004 06:23 PM
