Door Card Compatibility - Defender Source
Old May 22nd, 2012, 11:53 AM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
My 110 has the roll-up window doors with the exterior lift-up door handles. My door cards are in rough shape and I'm interested in replacing them. Door cards for this kind of door are hard to find in good shape and for both front and second row.
Does anyone know if the later SW door cards are compatible with the older doors that I have? I know the door lock knobs are different between the two, and the interior door handle looks slightly smaller, but I'm wondering if you change those parts it would work. Has anyone tried this?
ATW!
- Jon
Old May 22nd, 2012, 12:35 PM
I only know this information for the front door. I know nothing about the second row doors.
With some modification. But not exactly.
The door lock knobs and interior door handles are not the issue. You can can change over to the later escutcheon system with a custom push/pull rod. The interior door handles pretty much fit without much issue.
I am doing this now. The real issue is the fact that the actual frame of the door differs between the old and new doors. Where this difference occurs is the side of the door that holds the latch. The new style doors "hump out" while the old style doors are much smaller. This results in the new style door card leaving a gap when attached to the old style door.
Filling that gap is really the only thing you have to worry about.
Old May 22nd, 2012, 01:03 PM
Miller's Avatar
Miller
Jon Miller
'85 ROW 110 SW
Thanks for the info, Ed. If my biggest concern is filling the gap between the door card and the frame, then I'll just fit the newer style cards to my doors. Do you have any pics of said gap?
ATW!
- Jon
door
Parts Compatibility tomaco1 Defender Technical Discussions 1 November 15th, 2007 12:02 PM
Fiberglass Hard Top Compatibility? cjadams Defender Technical Discussions 2 July 13th, 2007 03:36 PM
Odd intake compatibility question for Rover Tech types Hans Defender Technical Discussions 3 December 13th, 2004 07:39 PM
ARP head stud compatibility? Hans Defender Technical Discussions 0 November 12th, 2004 10:37 PM
Wondering about MAF compatibility Hans Misc. Chit-Chat 6 April 17th, 2004 01:43 AM
