Door Bottom Repair Channels - Defender Source
Old September 21st, 2010, 09:20 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
So I need to repair the door channel on my middle door before repainting. I have a 1983 110 and it looks like I need the Series-type door channels and the newer defender ones will not work. I have called around and it looks like RN is the only game in town? Anyone know of a secret source? Has anyone tried making the channels from scratch? Thanks in advance!
MUDSUX
Old September 21st, 2010, 09:24 PM
rovahfarm has them as does AB
Old September 21st, 2010, 09:27 PM
I have brought in and used quite a bit of the YRM metal specialties product. Exact match for the early 110 doors.
Old September 21st, 2010, 09:40 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I called Trevor and he said he does not have any early type. I'll have to check again with AB. I thought they only carried the newer defender ones. Doug will you sell me some?
MUDSUX
Old September 21st, 2010, 10:02 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I bought 4 from Trevor, but he said they were old stock. Later I bought another 2 from Paddocks, easy, fast and inexpensive. For my 4 doors I needed close to 1.5 pieces per door.
Old September 21st, 2010, 10:36 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
I've used the one's from AB and they are OK. It's a pretty easy repair. Take real good measurements. Remove the skin. Puddy knife and seaming pliers work well. Make sure you cut back to good metal or it can be a pain to re-weld as it's pretty thin metal to begin with. If you can hot dip the frame once you're done that's best. You can also dip them in a rust-proof liquid which is an OK option. Brushable seam sealer works well to re-attach the skin. Then a oak block on a soft wood board will work well to fold over the lip again. rubber hammer will also work. Good luck.
Cheers
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old September 22nd, 2010, 01:36 AM
grnrvrs's Avatar
grnrvrs
Paul
88
x2 on the galv and block of wood. Worked like a charm for me.
Old September 22nd, 2010, 06:28 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I did a little bit of a write up on my middle door repair in my "Project Frank" in the Truck Build-Ups sections. I made my own door channels. The welding can be difficult due to the thin metal, so cut back to clean metal and take your time. Well worth the repair versus buying new door frames.
Semper Fi!
Old September 23rd, 2010, 09:04 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Ok I'm confused. I thought the earlier defender/series door channels were not the same as the later defender type? Why is AB listing them as same? Anyone use the later ones to repair the earlier type doors?
http://www.roverparts.com/Parts/3540.cfm
MUDSUX
Old September 23rd, 2010, 10:10 PM
I don't have any to spare. The YRM stuff is an old guy and his wife-cottage industry. Their door channel is an exact match to the early 83-86 doors. I have spoken with the guy a couple of times and like him. He won't ship to the US or @ least wouldn't last we spoke. I have UK shipments coming and could have some shipped if you aren't in a hurry. His heavy aluminum battery box and tool boxes for the seatbox are awesome and end the dissimilar metal problem. Guess I should become his US distributor....
http://www.yrm-metal-solutions.co.uk...-parts-8-c.asp
Old September 23rd, 2010, 10:35 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by 130Tdi View Post
I don't have any to spare. Guess I should become his US distributor....
Yes please! I have tried to order from him from the past with no luck.
MUDSUX
Old September 24th, 2010, 01:03 AM
surf110's Avatar
surf110
Ze
130 Project
Doug,
If you bring these in, I'll buy a battery box from you.
Old September 24th, 2010, 10:24 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Has anyone used the ones from AB to repair the earlier 110/series doors? The guys at AB can't tell me if they are different or not between the early 110 and later defenders doors and will not verify for me. Thanks
MUDSUX
Old September 24th, 2010, 10:28 AM
grnrvrs's Avatar
grnrvrs
Paul
88
The later style pieces won't work right. Just buy them from the UK.
Old September 24th, 2010, 10:32 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
is a 93 rear door old style or new?
Old September 24th, 2010, 11:53 AM
What is pictured will work on soft top NAS D90, series and early door 90/110 83-86ish.
------ Follow up post added September 24th, 2010 11:53 AM ------
Middle door is "new" rear fifth door is old.
------ Follow up post added September 24th, 2010 11:56 AM ------
My understanding it there are two types.
"Old" which is all series doors, all early 90/110 doors to 86ish, NAS 90/110 SW rear (fifth on a 110) door which is on all defenders until 2005 or so.
"New" which is defender 90/110 roll up window doors front and middle.
Please correct me if I am wrong.
Old September 24th, 2010, 02:52 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Take a look at what you have and compare to this. Series on the right, defender on the left. The thickness of the material may be representative of series v defender, or it may be due to different manufacturers of the repair channels.
Name:	door repair.JPG
Old September 26th, 2010, 04:25 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
I ordered from YRM in May of this year and had the parts in about 4-5 days. Since their website will not allow you to select shipping to the US, I called them and we worked out shipping over the phone.
Old September 26th, 2010, 10:58 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
YRM had a booth at the LRO show , our Irish compadres really like using their repair parts
Chris "V"
Old September 27th, 2010, 12:38 AM
DieselDef
Brad Ingalls
1985 Defender
Is someone putting together an order for door channel? Seems like a few of us need some. I've got a right door bottom that is rotted out on my '85 and need enough for the bottom six inches. Where can I order it? Is there anyone on this side of the pond selling the right stuff to fit an early Defender?
Excuse my ignorance please but I don't recognize the 'AB' to whom some have referred. I gather that whomever AB is they supply parts and right now I'm in need of a number of items.
channel, door
RECO: Repair Manual for 95 SW reaper99999 Defender Technical Discussions 0 March 5th, 2006 05:07 AM
Corrosion repair ideas mattarm Defender Technical Discussions 6 February 2nd, 2005 10:18 AM
how to repair hard top crack? chirider Defender Technical Discussions 8 December 14th, 2004 08:11 AM
Speedo repair artm Defender Technical Discussions 3 October 21st, 2004 08:33 PM
roll cage repair willtillery Defender Technical Discussions 0 October 4th, 2004 09:15 PM
