Door Bottom Repair Channels - Page 2 - Defender Source
Old September 27th, 2010, 06:28 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'm confuzzled by those pics, those don't look anything like my door bottoms. Mine are 3 piece design and the ones above look to be 2 pieces.
Here's a pic of mine and the copy I made - looks like mine have an extra lip.
They are pretty easy to bend up, so if there is a market I can make up a batch.
Semper Fi!
Old September 27th, 2010, 07:11 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by DieselDef View Post
Excuse my ignorance please but I don't recognize the 'AB' to whom some have referred. I gather that whomever AB is they supply parts and right now I'm in need of a number of items.
AB is Atlantic British. I just ordered a pair last night out of desperation. I'll let you guys know if it will work or not.
MUDSUX
Old September 27th, 2010, 08:23 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
AB= Atlantic British http://www.roverparts.com/
------ Follow up post added September 27th, 2010 08:26 AM ------
Has anyone ever shot a video on the proper way to unskin and reskin door panels ? I have to do this on some Rovers and my 1961 MGA also and would love to see it done before I attempt it .
Chris "V"
Old October 1st, 2010, 09:18 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Forrest,
I used the AB channels to replace my 83 110 CSW front and middle door bottom channels...worked fine...
George
Old October 1st, 2010, 09:24 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by Gkase View Post
Forrest,
George
Thanks George for the info! Should be here in a few days.
MUDSUX
Old October 5th, 2010, 10:03 AM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Originally Posted by grnrvrs View Post
Take a look at what you have and compare to this. Series on the right, defender on the left. The thickness of the material may be representative of series v defender, or it may be due to different manufacturers of the repair channels.
Yup just got mine in and it's the one on the right. Same profile as my older-style split doors.
MUDSUX
Old October 5th, 2010, 12:11 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Good, glad you got the right ones. Wolfs version is a bit of a mystery, never seen a LR (Series, 90 or 110) door channel profile other than one of the two posted earlier.
Old October 5th, 2010, 04:13 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
So I started working on the door repair. It was pretty easy peeling the skin off the frame. My concern is the area where the hinge bolts to and the door retaining mechanism. Can anyone with experience tell me how you dealt with that area? Did you just cut it off and drilled new holes for the door hinge? It looks like there is a tube in each hole to prevent the channel from getting crushed when you bolt up the door. Thanks
ID:	31868   Click image for larger version
ID:	31870   Click image for larger version
MUDSUX
Old October 6th, 2010, 03:11 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Bumpity-bump Anyone? I can't seem to remove the door retainer without removing atleast one door hole/tube.
MUDSUX
Old October 6th, 2010, 03:41 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I had a buddy of mine do the welding on my doors this past summer. We had to build a template/jig that would center each of the holes. This was to ensure the proper spacing and perpendicular orientation for the new hinge bolt tubes that were welded into the new door frames. Another challenge was to replicate the reinforcing plate on the skin side of the frame to which the tubes were welded. This plate had to be recessed into the flat of the door frame. HTH.
Old October 6th, 2010, 04:05 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
....We had to build a template/jig that would center each of the holes. This was to ensure the proper spacing and perpendicular orientation for the new hinge bolt tubes that were welded into the new door frames. Another challenge was to replicate the reinforcing plate on the skin side of the frame to which the tubes were welded. This plate had to be recessed into the flat of the door frame. HTH.
Shit.
MUDSUX
Old October 6th, 2010, 05:46 PM
Cut the old plate and tube out, clean it up, and install it in the new channel.
Old October 6th, 2010, 06:01 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I wish mine had been salvageable. Placement is still important, IMO its worth the time to build a jig.
channel, door
RECO: Repair Manual for 95 SW reaper99999 Defender Technical Discussions 0 March 5th, 2006 05:07 AM
Corrosion repair ideas mattarm Defender Technical Discussions 6 February 2nd, 2005 10:18 AM
how to repair hard top crack? chirider Defender Technical Discussions 8 December 14th, 2004 08:11 AM
Speedo repair artm Defender Technical Discussions 3 October 21st, 2004 08:33 PM
roll cage repair willtillery Defender Technical Discussions 0 October 4th, 2004 09:15 PM
